Finishing a child's stepstool
Forum topic by Andrew posted 12-28-2011 04:46 PM 1046 views 0 times favorited 3 replies Add to Favorites Watch
View Andrew's profile
Andrew
316 posts in 2396 days
12-28-2011 04:46 PM
Topic tags/keywords: slip slippery finish step stool
I am building a stepstool for a small child. What is the best type of finish that will look nice, be protected from moisture (used in the bathroom) and, prevent slipping with little wet feet?
I was just going to use polyurethane but I am concerned it might be a bit slippery.
Thoughts?
-- Andrew - Albany. NY
3 replies so far
Andrew
#1 posted 12-28-2011 06:36 PM
Also, what type of non-skid shoes do you guys recommend (if any) for the bottom of the legs?
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3742 days
#2 posted 01-09-2012 06:05 AM
I think just about any finish will reduce the coefficient of friction between the wet feet and the stool top or steps. Would a piece of rubber cemented to the top work for you?
Andrew
#3 posted 01-09-2012 06:06 AM
Well I did finish it with shellac and paste wax, it’s not as slippery as i had worried about. I told his parents that if they notice it being slippery, then we can address it later. So till they say anything, I’m not worried :)
Thanks!
