powder post beetle
Forum topic by bowtie posted 12-27-2011 04:23 AM 1658 views 0 times favorited 5 replies Add to Favorites Watch
View bowtie's profile
bowtie
990 posts in 2585 days
12-27-2011 04:23 AM
has anybody treated wood to kill powderpost beetles? i have some red oak 4/4
i found beeetle holes in after planing.
-- bowtie,.....jus passin thru....
5 replies so far
View BilltheDiver's profile
BilltheDiver
260 posts in 3124 days
#1 posted 12-27-2011 04:44 AM
You can treat with boric acid (timbor or boracare) but if any pest control businesses in your area do fumigation (tenting) for drywood termites and have a vault, they can gas it for you with no residue and immediate results. If tenting is common in your area, call around and ask who has a vault for furniture. You may be too far from the Gulf for drywoods to be common.
-- "Measure twice, cut once, count fingers"
bowtie
#2 posted 12-28-2011 03:40 AM
thanks for the advice. i plan on using this oak in a corner behind our wood heater and i want to be sure the beetles and their larva are dead.
View WDHLT15's profile
WDHLT15
1797 posts in 2715 days
#3 posted 12-28-2011 08:19 AM
Applying a borate solution will not kill the eggs or the larvae that are already in the wood. It is a surface treatment. Heat is the best treatment once the wood is infested. That will likely require a kiln. The internal wood temp has to reach 140 – 150 degrees for 4 or 5 hours. Internal wood temp, not surface temp.
View Nomad62's profile
Nomad62
726 posts in 3197 days
#4 posted 12-29-2011 12:28 AM
You might check your supplier if you can; if the wood has been kiln treated then the wood will be just fine. Kiln treated, not simply dried. Treatment needs to get the wood to 133 degrees f thru and thru. If it has been treated, then it will be ok. If not, you may need to. Liquid solutions require the wood to be wet to work; they mix with the current moisture in a wood and can reach the center of said wood and all bugs and larvea are done for. They do not necessarilly work on dry wood, as there isn’t necessarilly enough moisture to carry the liquid you try to use. If you can’t do any of this, then use it anyway and watch for little piles of sawdust (frass) that accumulates on or at the base of the wood when it gets good and warm. They can survive a few years as eggs under premium conditions.
View Milo's profile
Milo
869 posts in 3558 days
#5 posted 12-29-2011 09:07 PM
I reclaimed and entire barn last year, and was concerned about PPB’s, but I wonder if these things sometimes move on or what. It’s the second time I’ve been around “supposably” untreated wood that had PPB holes, but no beetle or larvae. I’ve cut, planed and jointed enough of it by this time to have found them if they were there.
Then again, may it wasn’t PPB’s…
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
