Wood lathe to metal lathe...mild steel
Forum topic by D_Allen posted 12-26-2011 05:32 AM 873 views 0 times favorited 1 reply Add to Favorites Watch
View D_Allen's profile
D_Allen
495 posts in 2746 days
12-26-2011 05:32 AM
I needed bushing to make this flat top pen and did not have the correct size.
Tried some brass ferrules but they did not fit snug enough on the adapters.
What I found out is that the steel used for the spacers that came with my mandrel saver are of mild enough steel that I was able to turn them down to fit in the adapters for my centers. I used a HSS parting tool. Yes, I did have to sharpen it afterward but not a lot. I got the same close fit as with the 7mm tubes. All of the parts-to-wood transitions on this pen are excellent. A spacer like the ones used is in the center. They do look more like some kind of cast metal. Definitely not machined like the bushing sets or the adapters for turning on centers.
-- Website is finally up and running....www.woodandwrite.com
1 reply so far
View lew's profile
lew
12015 posts in 3717 days
#1 posted 12-26-2011 06:03 AM
Cool Idea!
I had to modify a bunch of screw heads a couple of years ago and used this idea. Instead of the parting tool, I used machine tool bit stock and held it with some vice grips.
Lew
