another jointer problem
Forum topic by Jeff82780 posted 515 days ago 1062 views 0 times favorited 13 replies Add to Favorites Watch
View Jeff82780's profile
Jeff82780
93 posts in 1165 days
515 days ago
hello everyone and merry christmas. well as some of you know i am building my first woodworking bench. I was having a real difficult time jointing long 8’ boards for the top. I thought the problem was that i wasn’t keeping the board supported. So i decided to build some infeed and outfeed extensions for my jointer. so i cut some 2×6’s down to 3’ and was ready to mill. well to my dismay, things still are not working out to well. so now i am either having a technique problem or jointer setup problem. I watched the wood whisperers jointer setup for tips on how to do thiswtedious process. my knives all are fairly aligned, i took measurments on the infeed table using a straight edge and feeler gauges and the end result was .002 for the front and .005 for the back. i have the rigid jointer so gibs and dovetailed ways are used for table alignment. To be honest the gibs and ways really confuse me. So i figured .003 wasn’t that bad. at least not bad enough to mess up jointing a board. Marc spagnola never mentioned anything about adjusting the outfeed table so i left well enough alone. So after an hour or so of tuning up my jointer and went for it again. Same result another poorly jointed board. So now im thinking its my technique. This is how i approach this task at hand. I first look for the cupped side and then joint this side face down. i then slowly push the wood into the jointer. after the end of the board clears the knives i transfer all my pressure to the outfeed. The first half of the board seems to joint perfectly its the laater half that ends up all uneven and instead of being cupped th e board turns out convex. I took some pictures of the pocess so you guys can unerstand whats happening during the process
joint cupped face down
board starts to taper from so many passes
2nd pic- after 1 pass
3rd pic- after 3 passes
4th pic- after 12 passes
5th pic- tapered from so many passes
13 replies so far
View ChuckV's profile (online now)
ChuckV
1756 posts in 1698 days
#1 posted 515 days ago
Jeff,
Merry Christmas.
Are the infeed and outfeed tables co-planer?
You said that you did not adjust the outfeed table height. Did you test it? It should be either at the top-dead-center of the blades or slightly below (there are differing opinions on this). I set my outfeed table so that a 12” rule placed on its side with 9 inches on the outfeed table will be moved 1/8” toward the infeed side by the blade when rotated by hand (with the machine unplugged!). I test this nine times. For each of the three blades, I test it on the two ends and the center.
Good luck.
-- I was walking down the street, something caught my eye, and dragged it 15 feet.
View casual1carpenter's profile
casual1carpenter
250 posts in 647 days
#2 posted 515 days ago
Jeff , Question, are your feed tables, i think the word is coplanar? if you set the infeed and out feed tables at the same relative height would a straight edge touch at both outside ends and at the ends near the knives? I believe the infeed and outfeed tables need to be on parallel planes, just different in height for the amount of material you desire to remove.
I hope this gives you some thoughts till one of the smart guys wakes up or checks in. Also hope I understood your problem right
View D_Allen's profile
D_Allen
495 posts in 955 days
#3 posted 515 days ago
It could also be that you are pressing too hard at the start and not enough at the end.
That looks like pine and it will flex a lot in this case.
Here’s a test you could do. Try doing the edge of a board with the fence all the way to the back.
Check the width before and after and see if you get a consistent cut from one end to the other.
Then move the fence to the middle and run it again, and again with the fence to the extreme front.
That will give you an idea of how much if any the tables are out from being coplanar.
I’d also suggest that you try it flat again with the cup down as you have been. But do not put too much pressure downward. I’m assuming here that you do not have a planer as that would be the best way to flatten this board.
-- Website is finally up and running....www.woodandwrite.com
View TCCcabinetmaker's profile
TCCcabinetmaker
743 posts in 526 days
#4 posted 515 days ago
I feel special, because you didn’t go back and read my last response on your last thread that adresses the issue you are still having.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
Jeff82780
#5 posted 514 days ago
d-allen i did that test u said to do my results were as follows. when the fence was all the way in the back only the first half of the board was edge jointed same with as the fence moived to the middle. However, when i moved the fence all the way foward the board was edge jointed perfectly! so know how do i make my tables co-planer?
casual1carpenter
#6 posted 514 days ago
I might be wrong but I think you need to rule out the table alignment.
then do the rule flip one eighth thing with the rule and knife edges as ChuckV suggested.
Hope this helps, if the tool is out of whack you get out of whack results dude, might not be operator error except in the fact that you believe the tool to be correct.
View Al Killian's profile
Al Killian
86 posts in 796 days
#7 posted 514 days ago
If the tables are out of wack, front to back. This can be fixed byadding machinest shims to the low side under the table. Add a small amount at a time and go back thru to check for flatness.
-- Owner of custom millwork shop
Jeff82780
#8 posted 514 days ago
ok. they are definatley not coplaner. i raised the infeed table all the way and then raised the outfeed table until it was in lign with the infeed. it seems to be that the outfeed table is saggin in about .009. So all i have to do is shim both sides of the outfeed table at the high side (since the table is saggin inward) with .009 feeler gauges?
View sawblade1's profile
sawblade1
750 posts in 1198 days
#9 posted 514 days ago
Been a while since I have been here But hers it Goes
Pic 1 Cup is noticeable but also a slight twist is in the board is visible
Pic 2 Cup is being Planed off on first two Corners
Pic 3 Note set jointer to deeper level 1/16 passes 12 passes is too many
Pic 4 This is why you need a wood Planer humans cannot feed wood like machines and this is why you have the taper, ( take note) also working with Lumber like framing lumber takes a little more effort like making sure it is dry and storing it properly while doing so Even after bringing it home from the home center!!!!! along with cups twist mus be taken out before the jointer this is by finding the flattest part of the 2x and cutting it off on the mitersaw and then working out the twist this way ( not do not do this if it is too twisted Grab a circular saw first !!!!!)
Hope this helps :)
-- Proverbs Ch:3 vs 5,6,7 Trust in the lord with all thine heart and lean not unto your own understanding but in all your ways aknowledge him and he shall direct your path elmerthomas81@neo.rr.com
casual1carpenter
#10 posted 514 days ago
Jeff does this jointer have adjustments with the gib things on the dovetail slides? Saw somewhere that adjustments were possible on new fangled machines without resorting to cigarette filters and packing tape. Now my monster is old and has no means of adjustment for coplanar that I have found. I do have to use feeler gauges to get even a reasonable cut, one of these days I intend to remedy this with drilling and taping and hope not to destroy it in the process.
Al Killian
#11 posted 514 days ago
If both(front and back) of the table are sagging then yes, shim both. I usally use brass shims that I get from local machine shops. They carry them in different thicknesses. Grab a few of each thickness and then you can mix and match to get it at proper level.
View able339's profile
able339
47 posts in 546 days
#12 posted 514 days ago
Back off on the amount of pressure you are applying to the boards to start with. Take skinny cuts until you achieve flat.
-- TNJames
View renners's profile
renners
1893 posts in 1140 days
#13 posted 514 days ago
Come to think of it, I had an issue planing boards straight just a week ago – my euro style planer thicknesser was planing a bow after a chip had settled on the mount under the outfeed table. When the outfeed table was locked back down the chip was raising the end of the table so it wasn’t co-planar, causing a bow. Just goes to show that even the slightest misalignemt can cause problems.
-- Do or do not, there is no try
