clock inserts
Forum topic by cebfish posted 12-26-2011 04:54 AM 1461 views 0 times favorited 5 replies Add to Favorites Watch
View cebfish's profile
cebfish
156 posts in 2809 days
12-26-2011 04:54 AM
i need some tips or tricks on installing 1 3/8” clock inserts
5 replies so far
View dankc908's profile
dankc908
28 posts in 2487 days
#1 posted 12-26-2011 04:00 PM
Are you talking about a 1-7/16” insert in a 1-3/8” hole? That is what I am, typically, using. I drill the hole with a 1-3/8” forstner bit about 1/4” deep and the insert, with the rubber gasket, fits in tightly. I’ve not found a 1-3/8” insert. This seems to be the standard.
-- Dan Christensen "We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light." --PLATO
cebfish
#2 posted 12-26-2011 08:43 PM
i am drilling the hole with forstner bit but the insert will not go in with out the rubber gasket rolls or squish out. is there any tricks to getting in
View StumpyNubs's profile
StumpyNubs
7650 posts in 2922 days
#3 posted 12-26-2011 08:55 PM
The best part about installing clock inserts is how easy it is to time your progress…
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
cebfish
#4 posted 12-26-2011 10:26 PM
i think i figured something out. i replaced rubber gasket with a #67 o-ring. has any one tried this it seems to work l will see if it holds. i think progress is happening stumpynubs it was only a matter of time.
View Dusty56's profile
Dusty56
11822 posts in 3809 days
#5 posted 12-26-2011 10:40 PM
Depending on wood species , some have been a little harder to insert the clock into. I just lightly sanded the hole (breaking the sharp edge) and applied some paste wax to the rubber thingy….done : )
