Forum topic by Eagle1 posted 12-23-2011 11:37 PM 1841 views 0 times favorited 16 replies Add to Favorites Watch
View Eagle1's profile
2066 posts in 3001 days
12-23-2011 11:37 PM
Topic tags/keywords: jig
I am planing on building a new bench. It seems that the ones that I’m looking is only about 34” to 35” tall. I’m 6’3”. I’m kinda wondering what your bench heights are? Especially if you are a tall person.
Thanks for your imput..
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
16 replies so far
View Brandon's profile
4152 posts in 2887 days
#1 posted 12-24-2011 12:25 AM
What type of bench are you building? The height depends a lot on the type of work you do in addition to how tall you are. Will you be working with hand planes and chisels or power tools mostly? The former are lower the latter tend to be a little taller.
-- "hold fast to that which is good"
View poppatom's profile
116 posts in 2864 days
#2 posted 12-24-2011 01:24 AM
A good rule of thumb is belt buckle high. That’s the way I build everything in my shop, that way you’re not half stooped over causing your back to hurt.
-- Tom L. Williams ~ The difference between a man and a boy is the price of his toys.
View jmos's profile
821 posts in 2306 days
#3 posted 12-24-2011 01:37 AM
From what I’e read, it’s largely a matter of what you’re doing; if you use hand planes a lot, you want it low to allow your legs to do most of the work. Say, top as high as the middle of your hand. If you don’t do a lot of hand planing, as high as 36” works.
-- John
View wolflrv's profile
85 posts in 2307 days
#4 posted 12-24-2011 02:11 AM
I know I have my bench at 36” and it’s a great height for me to set up and use power tools, but it’s a bit too tall to get good torque when using a screwdriver by hand, or even for hand planing and sanding. I plan to probably drop the height about 3”..bringing it to 33”, but then again, I’m a short guy(granddaddy was a frenchman)...LOL! I did hear of one guy on another forum that ended up with a 42” bench, because he was 6’6”, so it just depends on back comfort and strain on the arms doing various functions. I’ve also heard bend arm at elbow and hold arm parallel over table and height should be 2-3” below elbow. I would definitely think if you’re 6’3”, then 34-35” would be a bit short for you.
-- Handcrafted toys, models & gifts at --
15250 posts in 2554 days
#5 posted 12-24-2011 02:20 AM
Build what you think, on the tall side, with the plan to take some off if you need to. How tall is your table saw?
404 - Not Found
2544 posts in 2905 days
#6 posted 12-24-2011 02:44 AM
What height are you comfortable working at? Hold some tools and get a friend to mark the height of an average height for holding a plane, handsaw, cordless drill etc, then take an inch off for material thickness, vice holding and work to that.
View Jim Jakosh's profile
Jim Jakosh
20180 posts in 3041 days
#7 posted 12-24-2011 05:11 AM
HI Tim. I’m 6 ft and my workbench with my tool boxes and my chair is 38” high. I built my router station at 38” too. My assembly bench is 34”. Make it comfortable for the work you will be doing at it.Taller person, taller workbench!
Merry Christmas, Tim….....................Jim
View NJWiliam's profile
32 posts in 2503 days
#8 posted 12-24-2011 06:31 AM
Better to start high with a design that allows you to shorten the legs if you’re not sure. I use a lot of wooden planes, so it’s even lower than is comfortable for metal planes . . .
View JoeMcGlynn's profile
219 posts in 2289 days
#9 posted 12-24-2011 12:22 PM
The Schwarz workbench books are a great investment, they cover dimensions. Your height will depend on your body size and the type of work you do.
-- Blog:
View helluvawreck's profile
30545 posts in 2803 days
#10 posted 12-24-2011 01:31 PM
Mine is about waste high but it also depends on what you are going to do with your workbench. Before building it I would invest in one or two of the good workbench books. They’ll give you some good ideas on what king of bench to build and all of the dimensions that you’ll need to consider.
-- helluvawreck aka Charles,
Craftsman on the lake
2779 posts in 3374 days
#11 posted 12-24-2011 01:50 PM
I used this rule of thumb, gotten from someplace online at a bench build site. For hand tool work stand up straight and put your arm to your side. Flatten your palm on the table. That’s the height that will be the most comfortable.
View HorizontalMike's profile
7749 posts in 2850 days
#12 posted 12-25-2011 05:26 AM
Less than 1/4in below my TS, in order to serve as an outfeed table, an important consideration.
View BTKS's profile
1986 posts in 3400 days
#13 posted 12-25-2011 05:44 AM
I set my table to outfeed height. As others have said, beltbuckle high is a good middle ground. Seriously, if your shop is cramped for space, having all benches and most stationary tools at the same height is a God send. Larger stock is much easier to work on and move. Just my two cents. Good luck, BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View MrRon's profile
4676 posts in 3179 days
#14 posted 12-27-2011 06:26 PM
I find that a workbench height that matches the outfeed height doesn’t work for me. The workbench top will always be cluttered with tools, wood, etc to use it for an outfeed. Besides, I have a 1200 sq ft shop. I have been working on a design for an adjustable height workbench, using hydraulic jacks, but can’t get it sturdy enough or cheap enough to build.
View richgreer's profile
4541 posts in 3010 days
#15 posted 12-27-2011 06:38 PM
My workbench sets about 2’ from my 18” bandsaw on the in feed side. The height of the workbench, 37.5”, is the same as the height as the table on my bandsaw. That is not a coincidence. FYI – I try to keep this end of the workbench clutter free.
Despite only being 5’ 10”, I find this to be a comfortable working height.
