| Forum topic by Woodhacker | posted 566 days ago | 443 views | 1 time favorited | 9 replies | ![]() |
566 days ago |
In searching LJ.com I see several hits on some incredible projects using double-double dovetail joinery, from Odie and a few others. I was wondering if any LJs have experience with hand cut double dovetail joinery. I’ve recently gotten the nerve up to try a keepsake box using hand-cut double dovetails. Since starting back into woodworking about 5 years ago, I’ve always admired the work than can be done with jigs, my initial exposure was magazine ads for the Incra jig. Then I saw them in person at a woodworking show and they were totally impressive in real life. And that got me thinking about trying them by hand. After studying the ads for a while it looked like the key was to cut a rabbet on the ends of the pieces the depth of the first (or “middle”) dovetail, and the thickness of the sides of the box. The picture below is my first practice attempt on one corner, using Poplar and Walnut. As you can see I made the rabbet on only one of the sides and didn’t realize the effect until marking out the second dovetail. The picture below is my second practice attempt cutting an inital rabbet on both of the Poplar pieces. The actual box I plan to make is using two different types of Rosewood for the sides and front/back, and using Maple for the “middle” dovetail. I plan to use thinner pins and a “middle” dovetail (the Walnut part) that is also not as thick. The Walnut “middle” dovetails in these photos are approximately 1/8 in. thick. I may try 1/16 in thick on the real thing, but that may be too agressive or risky. I was wondering if there are any LJs that may have already tried this type of hand joinery and could offer any advice, comments, tips, lessons learned, etc. Thanks. -- Martin, Kansas |
