What to make from a spare motor?
Forum topic by Dlow posted 12-23-2011 09:34 PM 3123 views 0 times favorited 13 replies Add to Favorites Watch
View Dlow's profile
Dlow
70 posts in 2773 days
12-23-2011 09:34 PM
Topic tags/keywords: question
I’m hoping to get some great ideas to put an electric motor I have to good use. It’s a 1/3 HP, 3 speed, 1050 rpm motor. I know it’s not a lot of power but there have got to be some uses I’m not thinking of… And lets rule out an air filter right off the bat, I have another motor with a squirrel cage fan already to be used for that purpose. Looking forward to seeing some the ideas from the great minds here.
13 replies so far
View jerkylips's profile
jerkylips
429 posts in 2656 days
#1 posted 12-23-2011 09:46 PM
industrial strength margarita maker?
View Mickey Cassiba's profile
Mickey Cassiba
312 posts in 3117 days
#2 posted 12-23-2011 09:56 PM
buffing system? the slow speed ought to be good for not burning finishes
-- One of these hammers oughta fix that...
View SASmith               's profile
SASmith
1850 posts in 3073 days
#3 posted 12-23-2011 09:57 PM
V-drum sander.
-- Scott Smith, Southern Illinois
View Lee Barker's profile
Lee Barker
2170 posts in 2936 days
#4 posted 12-23-2011 09:59 PM
What are the mounting options? I have an old motor with an accessory arbor on it on which I have stacked three wire brushes. Great for de-rusting and cleaning bolt threads and that sort of li’l stuff.
Kindly,
View jeth's profile
jeth
262 posts in 2924 days
#5 posted 12-23-2011 10:29 PM
A psa disc based grinding/sharpening unit, that’s exactly what I’m holding out for a 1/3-1/2 HP motor for and yours sounds ideal as it is lower rpm and I assume the “3 speed” gives you two other speeds below 1050rpm? If you can get access to it there was a good shopnotes article on a unit that sat on a drill press table and used an axle from the chuck to spin the discs, but you can do a standalone unit with a motor, pulleys and v-belts.
Check out the lapsharp sharpener foir thge general idea.
Other than that, a benchtop disc sander for light duty sanding tasks, or a conveyer belt to serve up sushi to workshop visitors?
View Brandon's profile
Brandon
4152 posts in 3037 days
#6 posted 12-23-2011 10:29 PM
A disc sander would be my suggestion. I’ve seen some nice ones here on Lumberjocks.
-- "hold fast to that which is good"
View Dlow's profile
Dlow
#7 posted 12-23-2011 11:49 PM
I thought about a sander but wasn’t sure that it would have enough power to do any real sanding( ie a drum sander). I like the idea of the grinder but other than occasionally touching up chisels I don’t know that it would get much use. It has about a 3” shaft so I could mount a pulley to that and it has 3 brackets attached to it’s face for mounting the motor itself. I think making margaritas in the shop would get me in too much trouble and I’m not a fan of sushi but thanks for the ideas so far. If I were to mount a larger diameter pulley to the motor and a small one to a sanding drum connected by a belt, it would spin the drum faster than the 1050rpm, but would 1/3 hp have enough “torque” to make it work as a drum sander? If anyone has any experience with this.
View Loren's profile
10477 posts in 3733 days
#8 posted 12-24-2011 12:51 AM
At the slow speed the motor runs at, it might make a good power
center for a buffing/grinding mandrel. Before affordable home shop
grinders came out, guys used to hook up a washing machine motor
under or behind a buffing mandrel. Mount a friable (white) wheel
on one side and a linen buff on the other and you have a slow-speed
grinder for your edge tools and you can put a razor polish on your
chisels and plane irons with the buff charged with jeweler’s rouge.
View Clouseau's profile
Clouseau
58 posts in 3119 days
#9 posted 12-24-2011 02:03 AM
Wire wheel on arbor.
-- Dan Coleman, retired Welding Inspector and past IA Teacher
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3122 days
#10 posted 12-26-2011 05:34 PM
Drum sander. You won’t regret it.
View popmandude's profile
popmandude
109 posts in 3106 days
#11 posted 12-26-2011 05:49 PM
Yet another vote for grinder, buffer, wire wheel. all together at one work station. Maybe removable top so said work station has multiple functions.
Let us know what you decide
Randy
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3798 days
#12 posted 01-06-2012 05:21 AM
A potters wheel?
View Dlow's profile
Dlow
#13 posted 01-06-2012 05:40 AM
Well I dont think a potters wheel would get much use and while I like the idea of a sharpening station, I don’t want to take up the limited space I have for something that will get minimal use. This project will be put on hold while I put a new motor in the truck, but thanks for the input everyone.
