Taper Jig
Forum topic by DHaden posted 12-22-2011 11:21 PM 2897 views 0 times favorited 10 replies Add to Favorites Watch
View DHaden's profile
DHaden
77 posts in 2621 days
12-22-2011 11:21 PM
Topic tags/keywords: jig tablesaw shaping
I am working on this valet (http://lumberjocks.com/projects/19902). I need a taper jig ( I think) to cut the sides from 3” to 1 1/2”. Any suggestions on how to build a taper jig or make these cuts with my TS? I was thinking of free handing a piece of scrap, but would like something adjustable to be able to use in the future for other project that need a taper cut. How do y’all solve this delima?
D Haden
MERRY CHRISTMAS!!!
-- Measure once, cut twice.
10 replies so far
View GerryB's profile
GerryB
69 posts in 2544 days
#1 posted 12-22-2011 11:50 PM
Last time I noticed one was less than 20USD at Rockler.com
-- The pursuit of excellence is gratifying and healthy. The pursuit of perfection is frustrating, neurotic, and a terrible waste of time. Edwin Bliss
View Fuzzy's profile
Fuzzy
298 posts in 3951 days
#2 posted 12-23-2011 03:25 AM
I built one based on the plan presented by Charles Neil … works GREAT !!! ... and is fully adjustable + VERY SAFE … AND quite easy to build. Nothing but some scraps & a few knobs & threaded rod for hold downs. It can be built in a few hours, and should last a lifetime.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View Jim Finn's profile
Jim Finn
2647 posts in 2884 days
#3 posted 12-23-2011 04:31 AM
http://www.plansnow.com/taperjig.html <<<<<< I built one similar to this one. Works great.
-- Website is https://craftingcouple.com/
View SnowyRiver's profile
SnowyRiver
51457 posts in 3443 days
#4 posted 12-23-2011 04:51 AM
A taper jig is the quickest if you do tapered cuts from time to time. Another way to do the taper if its a one time thing for you is to mark out the tapered line, cut the piece with a circular saw, or jig saw, about 1/32 or so outside the line. Then take a straight edge like a piece of 3/4 straight stock and clamp it right on the line then use a router and trim bit with the bearing on top of the cutter to clean up the cut.
-- Wayne - Plymouth MN
View devann's profile
devann
2246 posts in 2655 days
#5 posted 12-23-2011 05:55 AM
Here’s a real nice one by a fellow LJ http://lumberjocks.com/projects/43389
DHaden
#6 posted 12-23-2011 06:45 AM
Thanks for all the great ideas. I will get back to here with my solution.
View toolie's profile
toolie
2120 posts in 2591 days
#7 posted 01-25-2012 02:29 AM
here’s a really simple, cheap alternative. just get a piece of melamine or mdf (both 3/4”) for a sled that is 2-3” wider, and at least 2-3” longer, than the unfinished workpiece. set the fence so that the sled just fits between the blade and the fence. double side tape the workpiece to the (melamine or mdf) sled with the cut marks lined up with the sled edge that is adjacent to the TS blade. push the sled, making sure that it hugs the fence. no damage to the sled and the workpiece is safely cut. easy way to rip long tapers without spending $200 on a tapering jig.
Jim Finn
#8 posted 01-25-2012 04:55 AM
Here is the one I made. Works well for me…....http://lumberjocks.com/projects/59147
View danr's profile
danr
154 posts in 3147 days
#9 posted 01-25-2012 06:08 AM
DHaden,
I built a taper jig (I call it a taper sled) that is like the one that was provided in the link above from plansnow.com. My sled was concieved by an artical that I found in shop notes many years ago. This type of tapering jig is a bit different than your typical hinged taper jig. The one that is shown in the plansnow.com link and the one that I am referring to (i.e. the one that I built) allows you to cut a taper on all 4 faces of a table leg (for example). The leg starts off square. You can also use this jig to make a taper like the typical hinged taper jig but it is a bit different to set up and over-kill for the standard taper cut.
The typical hinged taper jig is easy to make and I have made several on an as needed basis. I would recommend that you use this wonderful web site (i.e. lumber jocks) to find some examples and then just make a quick jig that will meet your needs. Sorry that I can not provide you with a photo of what I am talking about.
View Chipy's profile
Chipy
374 posts in 2556 days
#10 posted 01-28-2012 11:24 PM
I got one at Sears 12 beans discounted! Maybe you can catch the same deal.
