Bandsaw Blade Guard
Forum topic by Chris Love posted 12-22-2011 11:18 PM 3730 views 0 times favorited 12 replies Add to Favorites Watch
View Chris Love's profile
Chris Love
34 posts in 2468 days
12-22-2011 11:18 PM
Have you taken off your blade guard on your bandsaw?
I have ruined two blades that dulled on the guard and I am wondering how many people keep them on?
I have 37 years of wood working experience (only a couple of months with a bandsaw though). 8 years ago I had a mishap on my table saw and cut off 1/3 of one finger and 1/8” off of two more. I have never used the guard on my table saw.
Thanks.
-- Chris, Bremerton, WA
12 replies so far
View Blakep's profile
Blakep
232 posts in 2824 days
#1 posted 12-22-2011 11:26 PM
I use mine on the bandsaw. It has never got in the way or been a problem so I have never thought about taking it off. I don’t use one on the table saw though as they do get in the way.
View Elizabeth's profile
Elizabeth
817 posts in 3165 days
#2 posted 12-22-2011 11:32 PM
Never occurred to me to take it off – seems like an important safety feature. I have a Grizzly bandsaw which until recently had the stock guard on it, with no problems. I recently got the Carter upgrade which came with a new guard; I have attached it but haven’t had a chance to use it yet.
If my blade was getting dulled by the guard I would consider that a problem with blade placement which might indicate slippage or something else that needs dealing with asap.
Blakep
#3 posted 12-22-2011 11:35 PM
I agree ^. The guard is out of alignment somehow or your blade is drifting or something is not right if its coming in contact with the guard.
View ChuckV's profile
ChuckV
3123 posts in 3549 days
#4 posted 12-22-2011 11:39 PM
Are you referring to the guard on the “up” or “down” side of the blade? In either case, I too suggest that you determine why the blade is contacting the guard.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
Chris Love
#5 posted 12-22-2011 11:50 PM
I know why the blade contacted the guard…and although I have addressed the issue and will continue to fine tune; it may hit it again. It only takes a couple of seconds against the metal guard to ruin a blade. The guard is mounted as far away from the blade as it can go and the tracking only has to move a little when the stress from feeding is released.
Blakep
#6 posted 12-23-2011 12:02 AM
What kind of saw do you have? I can tug and pull on my blade while it is running and it never hits the guard. Do you have enough tension on the blade?
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3607 days
#7 posted 12-23-2011 12:20 AM
If you’re blade is rubbing on the guard as it’s used something is wrong .Try tofine tune ,or expand the guard or adjust, tighten blade, or get anew guard , but in any case it shouldn’t do that during normal use.It seems you’ve lost enough fingers so take using the guard seriously bandsaws are dangerous just like table saws the will remove your hand with a moments lack of attention play and work safe my brother. Alistair
Elizabeth
#8 posted 12-23-2011 12:23 AM
Well, if you know what caused it and are concerned it might happen again…I would maybe consider making a guard out of some material that will protect me from accidentally impacting the blade with my hand but will not damage the blade if the blade wanders a bit. Maybe a wooden or PVC inner guard with a layer of something harder (aluminum? steel? Something that won’t cut through instantly in case of a freak hand accident) on the outside?
View StumpyNubs's profile
StumpyNubs
7598 posts in 2822 days
#9 posted 12-23-2011 12:26 AM
The guard above the blage guides is important. Imagine leaning your head to get a closer look while cutting something and catching the blade in the forhead…
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
View doninvegas's profile
doninvegas
334 posts in 2929 days
#10 posted 12-23-2011 01:29 AM
I have a 14” Delta BS and the first time I took the guard off I could never get it back on so it didn’t rub on the blade or keep the upper door to closing. It was never bent or dropped but for the life of me I couldn’t get it right. I took it off and chucked it. The saw works great and I don’t feel it’s dangerous. Everyone has different comfort levels when it come to wood working safty. I’m comfortable with this.
-- "Courage is being scared to death -- but saddling up anyway."
View Dusty56's profile
Dusty56
11819 posts in 3710 days
#11 posted 12-23-2011 02:46 AM
SAFETY FIRST ...unless it gets in the way !
View gfadvm's profile
gfadvm
14940 posts in 2712 days
#12 posted 12-23-2011 05:09 AM
I’m with Stumpy. Brain surgery via the band saw is not something I want to contemplate. Way to go Stump. I’ll probably have nightmares now!
