Sanding after initial shellac coat gumming up...
Forum topic by widwotkma posted 12-20-2011 10:31 PM 9767 views 0 times favorited 14 replies Add to Favorites Watch
View widwotkma's profile
widwotkma
40 posts in 2627 days
12-20-2011 10:31 PM
Topic tags/keywords: maple sanding shellac
I made a cross as a Christmas present for my parents out of figured maple and purple heart. The cross itself turned out reasonably well, considering it was my first such project. The cross is essentially made up of 7 pieces of wood glued together.
Maple cross w/ purple heart
I wanted to “pop the grain” so after sanding to 200 grit, I applied a coat of Zinsser Bulls Eye Seal Coat (dewaxed shellac) mixed with about 7 drops of TransTint. After that dried, I tried sanding with 220 grit, but got globs that built up on the surface. I was able to remove them carefully using a razor blade, but am now uncertain what to do to get to the next step (the plan is to add several coats of an oil based finish (varnish).
Note I have another Christmas present project (this one a box – also done with the maple and purple heart, plus a lid of ambrosia maple) and I applied the same initial finish. I have not yet sanded it, in hopes I can avoid having the same issue with it.
Ambrosia maple lid
Maple box w/ purple heart keys
Any thoughts/ideas/tips/tricks would be much appreciated. I’m obviously quickly running out of time to finish these!
Thanks much
14 replies so far
View Gary's profile
Gary
9386 posts in 3668 days
#1 posted 12-20-2011 10:34 PM
How long did it dry?
View jmos's profile
jmos
905 posts in 2605 days
#2 posted 12-20-2011 10:41 PM
My understanding is shellac will do that if it is not completely dry, or if it is old. If letting it dry longer doesn’t do it, you can remove the shellac with denatured alcohol. A good rub down may remove enough to let you reapply fresh shellac, or try another finishing method.
-- John
View PurpLev's profile
PurpLev
8548 posts in 3884 days
#3 posted 12-20-2011 10:44 PM
sounds like the shellac did not fully dry yet. how long did you wait before you sanded the shellaced piece?
widwotkma
#4 posted 12-21-2011 01:49 AM
Thanks so much for the quick responses.
I had let it dry overnight thinking that would be long enough, but maybe not. The can of shellac is new (purchased several weeks ago) so I don’t think it is an age issue. Does temperature have any impact? My garage is not heated and it has been in the 40’s lately.
I will try to remove the shellac from the cross with denatured alcohol, resend and start over. I have let the box dry several days now and will try sanding it tonight to see if I have better luck. I’ll keep you posted…
View trophy's profile
trophy
8 posts in 3313 days
#5 posted 12-21-2011 02:13 AM
With your unheated garage and low temperature you will need to move the items into a warm DRY area for the finish to cure properly. Dampness, as well as temperature are also big no no’s with shellac as it will not cure properly and will remain gummy. Your projects are very nice and will look great once you resolve the shellac curing problem which in my opinion is environmental. You still have ample time to refinish them, jmos is correct with using the alcohol to remove the shellac as a starting place. Good Luck and Merry Christmas
-- Bruce, Upstate New York
View jmos's profile
jmos
#6 posted 12-21-2011 02:21 AM
You might also want to try bringing them inside overnight. Temperature always effects drying time, lower is slower, but too hot can cause issues as well with some films. There is a significant difference in the vapor pressure of denatured alcohol between 40 and 70 degrees F. But, I would have thought overnight would have done it, even at 40deg F…
You might also want to check the date on the can; new from the store doesn’t always mean a new can.
-- John
View Alan Robertson's profile
Alan Robertson
67 posts in 4154 days
#7 posted 12-21-2011 03:20 AM
Been using shellac for awhile. Don’t panic, you’ve got a good base/sealer coat. Lightly sand high spots, (you would do this any way). If you haven’t sanded thru to bare wood—apply denat-alchohol to old t-shirt (wet) and start wipeing down the cross and box. The wipeing will soften the shellac and smooth it out, maybe giving you the base you want. I use this method for hand rub finishes.
After wiping (no sand) let dry.
50/50 mix———-turpentine or paint thinner or mineral spirits and polyurethane
brush-wipeon let firm up wipe off all excess repeat wait 12 to 24 hrs wax/buff
IMPORTANT KEEP WARM TAKE BUFFING & WIPEING RAGS OUTSIDE AFTER USING
-- MrAl
widwotkma
#8 posted 12-21-2011 03:58 AM
Thanks all, this has been extremely helpful and insightful. I have to wonder how people learned this stuff before the age of the Internet?!
I’ll post some pics of the final products. Hopefully they will turn out ok, but as this is my first batch of “real projects” I’m sure I have much more to learn the hard way. But that is part of the fun…
Merry Christmas!
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3522 days
#9 posted 12-23-2011 05:03 PM
Nothing against shellac, but if you are using an oil finish for the top coat anyway, you could use Tung Oil, Boiled Linseed Oil, etc, to pop the grain. That’s what I am using on my boxes and it works well. I usually thin it with mineral spirits, but have also used it straight out of the can. You can come back with the next coats quicker this way.
I agree with everyone on the drying time. That is usually what makes a finish gum up like that.
-- http://shepherdtoolandsupply.com/
View yooper's profile
yooper
223 posts in 3063 days
#10 posted 12-23-2011 05:19 PM
I highly recommend Arm-R-Seal by General Finish. I have used Seal Coat Shellac and BLO, but was blown away by how easy Arm-R-Seal is to use and how nicely it finishes. It contains BLO I believe, so it pops the grain nicely.
-- Jeff, CT - keep calm and make sawdust
View JasonD's profile
JasonD
180 posts in 3097 days
#11 posted 12-23-2011 07:42 PM
Shellac is a great finish, but you can’t always trust the premixed can stuff. Just because you bought it from the store recently, it could have been sitting on their shelves for quite some time before you picked it up. There is a date stamp code on the can (should be about 5 or 6 numbers).
Also, I’ve had cans of Zinsser that were only about 6 months old according to the date code, but when I tried to use them, it was clearly bad. One thing you have to consider is that with the premixed stuff, no matter how old it is, we don’t know what kind of conditions (ie: temperatures) it was exposed to in shipping, warehousing, etc.
Mixing your own shellac from flakes is really easy and costs less than buying premixed. Plus, you have the benefit of only mixing what you need for a given project. So, you don’t have to worry about it going bad before you use it. Check out shellac.net. They have great prices and their customer service is outstanding. With some flakes, denatured alcohol from a local hardware store, and a $20 kitchen scale from Walmart, you’ll be in business.
I put off trying to mix my own for a long time; worried that I’d mess it up, but it’s ridiculously simple. I’m kicking myself for not trying sooner. If you have any questions, don’t hesitate to ask.
Btw, beautiful work on the cross and box!
View Tennwood's profile
Tennwood
112 posts in 3417 days
#12 posted 12-23-2011 08:08 PM
I love shellac because I can finish a project very quickly with a great finish. Like JasonD, I usually make my own, but you shouldn’t have this problem with the pre-mixed either. One trick I was taught was to wipe the wood down with mineral spirits once the shellac is dry. Then while it is wet with the MS, sand it using a 600 grit wet/dry sand paper instead of the 200 grit you are using. The 200 may be too aggressive for the sealer and it may not be totally cured. I can usually apply a coat every 30 – 60 minutes using this method. I’ll wait a day for my final coat. My shop is in the basement so I am sure having a constant temperature helps.
-- Jim, SE Tennessee, "Don't spare the kindling Dear, we have plenty"
JasonD
#13 posted 12-24-2011 12:39 AM
Tennwood, I agree the premixed shouldn’t gum up on him like that, but that’s assuming it’s still good. I’ve had some premixed that went bad on me before and it acted just like he’s describing above; stayed tacky, never fully hardened even after all the alcohol evaporated. The date on the can said it was only 6 months or so old, but when I asked someone more knowledgeable than me, they brought up the point that if it was exposed to higher temps for long periods of time during shipping, warehousing, etc., it could have gone bad.
View superstretch's profile
superstretch
1531 posts in 2929 days
#14 posted 12-25-2011 07:00 AM
I had some problems with an old can of wipe on poly I had this past week.. In some cases, I let it dry for about 40 hours and it still gummed up. What I found best was to take it back down to raw wood with some 0000 steel wool.. It doesn’t gum up, doesn’t mar the wood, and chews through the finish pretty quickly.
In some cases, I opted to not use the poly again and just wiped it down (and waxed a few of them).
The finished appearance was superb
-- Dan, Rochester, NY
