Need plans for a fireplace draft stopper!
Forum topic by ericrubash posted 12-20-2011 08:09 PM 3058 views 0 times favorited 5 replies Add to Favorites Watch
View ericrubash's profile
ericrubash
16 posts in 3237 days
12-20-2011 08:09 PM
Topic tags/keywords: fireplace draft question
I saw plans for a removable wooded fireplace draft stopper in one of my magazine a wihle back but cant seem to find it anywhere. Do any of you know what I am talking about ? Looks like the picuture below..
-- Eric Rubash, Nashville, erubash@priorityonebenefits.com
5 replies so far
View CaptainSkully's profile
CaptainSkully
1602 posts in 3757 days
#1 posted 12-26-2011 05:54 PM
I would think that you’d have to make a cardboard template to fit your particular fireplace.
-- You can't control the wind, but you can trim your sails
View Sawkerf's profile
Sawkerf
1730 posts in 3267 days
#2 posted 12-26-2011 06:34 PM
Should be simple enough to make – cardboard template for the opening shape and a frame with a piece of sheet goods cut to the template. Might also need some kind of “feet” to keep it upright.
I probably wouldn’t use wood for this – unless you wait until the fire is out before sitting it in place.
View wdwrkr's profile
wdwrkr
26 posts in 3200 days
#3 posted 01-17-2012 01:30 PM
I made something similar for my fireplace. I used the kerf style entry door weatherstrip (found at Home Depot, for example) around the perimeter of a plywood board. The kerf is cut into the narrow edge all around. As the board is pressed into the opening of the fireplace, the door seals compress to seal against the brick. This compression force keeps the panel in place, yet it is easy to remove.
You can then paint something interesting on the face of the plywood, or paint it black to minimize its appearance.
I opted for the minimal appearance route and did not use a handle.
I’ve since made several for friends and clients.
ericrubash
#4 posted 01-17-2012 09:04 PM
WDWRKR…do you have any pictures handy????
View Viking's profile
Viking
880 posts in 3394 days
#5 posted 01-17-2012 09:17 PM
Find a 300 lb. burglar to try to get down your 200 lb. chimney?
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
