Jet 14" Bandsaw - Suggestions for Improving Dust Port?
Forum topic by RedMac posted 12-20-2011 04:44 PM 4347 views 2 times favorited 10 replies Add to Favorites Watch
View RedMac's profile
RedMac
19 posts in 2469 days
12-20-2011 04:44 PM
Topic tags/keywords: bandsaw question
Good morning Lumber Js. I could use some input on ways to improve or replace the dust port on my JWBS -14CS.
The stock port is, allegedly, 2 1/2 inches, but the actual intake is much smaller than that. The short facts are that it doesn’t work for beans. I haven’t seen any available upgrades out there, but I can’t be the only one in the world who has this issue.
Any ideas or recommendations would be greatly appreciated.
Thanks and Merry Christmas. -r
10 replies so far
View hairy's profile
hairy
2703 posts in 3530 days
#1 posted 12-20-2011 04:55 PM
I had the same problem.
Here’s what I did.
It is much better now. I removed the old connector, it now sucks air in. There isn’t much clearance between the inside of the door and the lower wheel. My connector is on the outside, with only the screw heads inside.
-- My reality check bounced...
View Clouseau's profile
Clouseau
58 posts in 3030 days
#2 posted 12-20-2011 06:14 PM
I made one from half of the chip collector for a Rigid planer. They had them at ToolsNow on close-out. It took about 30 minutes. It uses either 2.5 or 4” hose. I bought a vew extra chip collectors you would like to send me your contact info.
-- Dan Coleman, retired Welding Inspector and past IA Teacher
View Tyler's profile
Tyler
174 posts in 2691 days
#3 posted 12-20-2011 06:50 PM
Great ideas and great post. I have the same saw and same problem!
Clouseau
#4 posted 12-20-2011 07:14 PM
I don’t have any of my extras here at home, but I think this is the one: http://www.toolsnow.com/Planer_Dust_Collector_p/5932.htm
Looks like they still have them, and they are only #1 plus shippng.
I basicly chopped it in half and made the tab from some scrap plastic. You could use some from the wast half. If you rough it up, you can get supper glue to temporarily hold if you clamp it. Verify the tab location works BEFORE you drill and pop rivit it in place. Depending on your wheel cover you my need to add a washer to space it around the lip on the cover. Yoiu will need to remove it when you want to tilt the tabel for a bevel. Here are two additional pix. Don’t worry about adding the magnets, but you might want to install a little 1/8” thick foam.
View ptweedy's profile
ptweedy
75 posts in 3391 days
#5 posted 12-20-2011 08:09 PM
whats with the headlight and shocks??????
Clouseau
#6 posted 12-20-2011 08:16 PM
The pix were taken at my friend’s shop. I think it is an old Norton.
RedMac
#7 posted 12-20-2011 08:56 PM
Guys – Thank you so much for the input. I really appreciate the effort in getting those pictures up and doing some research into parts. That is way above and beyond.
View Egor's profile
Egor
135 posts in 3948 days
#8 posted 12-21-2011 02:14 AM
I will probably use both ideas for myself. Thanks.
-- Brock, Illinois
View GaryK's profile
GaryK
10262 posts in 3986 days
#9 posted 12-21-2011 11:50 PM
I did this: http://lumberjocks.com/GaryK/workshop
Look at the third picture. Works well, but nothing will get every speck of dust.
Clouseau
#10 posted 12-22-2011 12:50 AM
I just can’t bring myself to cutting the big hole in a perfectly good cover.
