| Forum topic by Ken90712 | posted 547 days ago | 1403 views | 0 times favorited | 27 replies | ![]() |
547 days ago |
Ok I have read a bunch of reviews on line and can’t seem to make up my mind! So I thought hey with all these friends I have made on LJ’s, and to the ones I have not had the pleasure of meeting who better to help me spend money! I have it narrowed down to two different drill presses. The 18 inch Delta or the 18 Powermatic. I really like both of them by the Delta seems to be calling me after reading many reviews. So please give me all your thoughts no matter if they’re negitive or positive.
I will also be buying a bigger Drum Sander and can’t figure out which one to buy as well.
You can post your comments or e mail if you prefer but any help would be great and if there are other machines you just love let me know them as well Thank-you in advance and Merry X-mas -- Ken, "Everyday above ground is a good day!" |
27 replies so far
#1 posted 547 days ago |
I’ve been very well served with the Delta Brand.The equipment is durable, reliable. The warranty is good and there is a wide network to get warranty service. Parts are also readily available locally or online. That’s my two cents worth of advice. -- Guy,PEI |
#2 posted 547 days ago |
Don’t think you could go wrong with either. But know this too, powermatic is owned by jet and the jet sander is really a performax since jet also bought them. I have a couple of jet products, my 6” jointer and my 14” bandsaw. never a complaint about the jointer. I did have issues with the bandsaw which jet was wonderful about but in hind sight even now I should have spent the extra $150 and got a delta simply because of the better design of the guide bushings on the delta. so what has a bandsaw got to do with your decision? Go and look, feel and inspect them in person. put your engineers cap on and give them a once over. Don’t be taken in by the shinny newness of their skins, look at the guts. Think of floor space too; it looks like the table crank on the PM DP is really long, will you have to move it away from the wall to use it every time? And, the performax sander looks less compact than the delta (I like the performax design better) will that cause you concerns? There, much more than my typical “nice” :-) Have a great Christmas and a happy new year old friend… |
#3 posted 547 days ago |
I had one of the first versions of the Delta, and it was a good sander as long as you didn’t sand much wider than 18-20”. Wider than that, and the boards had a tendency to burn along the edge of the sand paper. A friend had one like the Jet and was always complaining of alignment problems and the difficulty of adjusting for even sanding. If you can afford it, check with Woodmaster. I traded up to the 38” and couldn’t be happier. Never had any problems in over 3 years of almost constant use. -- Tim-- http://www.tmuli.com |
#4 posted 547 days ago |
Hi Ken I chose the Delta drill press a year ago and am extremely happy with it. Long stroke and more adjustments on the table. As for the sander check out the flat master available from Stockroom. I have a 24 inch one and am very happy. The thickness sanders I have tried dont sand to a uniform thickness from edge to edge. The flat sander will easily sand wider work without steps in the finish and clean up glue ups in a flash. Also very quick to change grits. It also works as a jointer as well – a 24 inch jointer is a neat thing. -- DonH Orleans Ontario |
#5 posted 547 days ago |
Mine is the delta floor model. I’m very happy with it, no trouble, drills anything. I also have the mortising kit, and it works quite well. hope this helps -- Angular error is proportionate to the distance run |
#6 posted 547 days ago |
Ken_c makes a very good point of the handle crank for the table. I assume you are going to put an auxiliary table over the cast one. If the crank interferes, it’ll drive you to drink. I have a Ryobi that I had to cut the crank off in half, so as not to clash with the auxiliary add-on. -- Government does not solve problems; it subsidizes them. |
#7 posted 547 days ago |
Ken, I have an older Delta drill press and was looking at these two as well. I probably read all the reviews you did. I have both a mix of Powermatic and Delta tools in the shop. No complaints with either brand. My nod for these two choices would be for the Delta. I played with both of these side by side in Woodcraft. I just liked the egos better on the Delta. The quick set depth stops pushes it over the edge. Also, I’ve read more bad things about the Powermatic. Seems to be a rash of lemons with this model. Constant burning rubber smell from the auto speed control, vibration etc. Besides, I love how the hood on the Delta looks like an old John Deere tractor front end. |
#8 posted 547 days ago |
Which ever ones you choose, you can send me your old ones :^) -- Lew- Time traveler. Purveyor of the world's finest custom rolling pins! |
#9 posted 547 days ago |
I have the jet 16-32. It works great, never had an issue with it. |
#10 posted 547 days ago |
I can only comment on the DS… I have the Jet 16/32… love it… would have liked to been able to afford the 22/44 oscillating head though… next time maybe… still I have been more than happy with the Jet…FWIW -- Drink twice... and don't bother to cut... @ lazylarrywoodworks.com.au For lovers of all things timber... |
#11 posted 546 days ago |
Look to be a very nice shopping holiday in Ken shop! I think you can’t go wrong on either, would love to have em in my shop. What every you pick will make a great addition to you arsenal Ken, have a great Holiday Season and give my best to Ms. Blondie as well your friend in woodworking Wilson |
#12 posted 546 days ago |
I can tell… You ARE going to have a Merry Christmas! Great! -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#13 posted 546 days ago |
Drill Press / I researched the Pm and the Delta and looked at the promo video’s on u-tube as well. From what I came up with I end up ordering the Delta (hopefully it will be here before X-Mass) I ordered mine from Tools- Plus and got a good deal. There was just a big conversation about these two presses on Woodnet discussing the same question. One of the individuals had the Pm and sold it at a loss and traded it for the Delta. I have read a lot of complaints about the Pm. Drum sander/ I had a Performax 16/32 and it worked well for small things but I ended up getting a 38’’ Woodmaster and love it. Good luck in your decision… Look under this heading in the Woodnet Forum I just bumped it up to the top of the page in the “Woodworking Power Tools section” Powermatic 2800 or Delta 18-900L drill press #5693127 – 11/23/11 03:40 PM |
#14 posted 546 days ago |
Add me to the group that likes the Performax 16-32 Plus. I have one and don’t know how I did without it. I should also note that mine is old enough (purchased used) that it still has the Performax name on it, and does NOT have their new feed belt design. The one thing I don’t like about the Delta design is that the table moves, not the drum. That’s all fine and dandy, as long as you’re aren’t using a fixed height outfeed table. Speaking of which, no matter which one you get, spring for the outfeed extensions if they’re available. They make a HUGE difference if you’re sanding anything more than a couple of feet long. In my experience, most drum sander burn problems are operator error (been there), not the fault of the machine. Remember, we aren’t talking about a planer here. The manual may say that you can take a quarter-turn of the handle (1/64” = ~.016”) per pass, but I have found that most hardwoods do much better at an eighth of a turn (1/128” = ~.008”) per pass. And, if I’m sanding end-grain hard maple (cutting boards anyone?) I drop that down to 1/12 of a turn (~.005”) or less. This is especially true with finer grits. I haven’t had any occasion to go wider than ~15”, so I can’t say how it does with wider stock (i.e. 2 passes). The question you need to ask yourself is, “How often do I need to go wider than that?” Just my $0.02 worth. P.S. I’m with degoose. If money were no object, I would have bought the 22-44 oscillating machine. -- There is nothing in the world more dangerous, than a woodworker who knows how to read a micrometer... |
#15 posted 546 days ago |
Put me on the list as having the Jet 16-32. I also love it and have had no issues. It’s a little workhorse. -- Gary, Los Angeles, video game animator |
| Forum | Topics |
Woodworking Skill Share
8848 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2101 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
