What the buff
Forum topic by thebenchroom posted 12-20-2011 06:30 AM 893 views 0 times favorited 1 reply Add to Favorites Watch
View thebenchroom's profile
thebenchroom
47 posts in 2479 days
12-20-2011 06:30 AM
Topic tags/keywords: finishing question
This finish is black lacquer with several coats of a clear lacquer, 600 grit sanding between coats. My problem is during the buffing stage. I picked up a buffing compound set from StewartMcdonald.com. The system is standard coarse,med,fine,swirl remover. One rotary pad per compound. I only have two pads, so I used the med and the fine. Ive been refinishing this old solid body guitar along side these tables using it as a test piece. The guitar cam out great, but the tops of these tables wont completly buff out. What do I do here? Sand back to the bare wood and start over?Try a untouched pad to see if it will buff out? You cant see in the pictures but when I look close I can see tiny deposits of the compound in the woods pores(maple).
-- Twitter-@thebenchroom
1 reply so far
View fussy's profile
fussy
980 posts in 3013 days
#1 posted 12-20-2011 07:10 AM
Start over. It looks as if you skipped some grits, left a rough surface, and that caught the buffing compound and held it. Black is a booger; it shows every mistake. I allways hated painting guitars black. Charged extra for black.
Merry Christmas
Steve
