Spraying laquer
Forum topic by spooled posted 12-20-2011 02:12 AM 917 views 0 times favorited 4 replies Add to Favorites Watch
View spooled's profile
spooled
27 posts in 3003 days
12-20-2011 02:12 AM
I just finished spraying lacquer on a stained oak veneer entertainment center I built for my daughter. Looks like i got some overspray in areas. I sprayed a primer coat and 3 coats of satin precatalized lacquer, sanding between coats. What is my next step to remove the overspray, and have a nice look like the rest of my project. The doors, end panels and top look great but the interior walls and floor got the over spray. Thanks
-- Charlie,Treasure coast
404 - Not Found
2544 posts in 2936 days
#1 posted 12-20-2011 03:25 AM
Sand down the affected parts and respray. Move or cover everything else up. I’ve tried cleaning off overspray with thinners but it’s never quite right.
spooled
#2 posted 12-21-2011 02:44 PM
Since the affected areas are behind doors, I sanded very lightly and buffed with a cotton towel. My wife can’t tell the difference. the finish is smooth and since it is such a dark coffee stain it looks fine. I wouldn’t have been able to get away with it on the outside top and sides. Thanks for the tips, esp. covering the adjacent walls.
View cracknpop's profile
cracknpop
294 posts in 2316 days
#3 posted 12-22-2011 06:53 AM
When spraying lacquer inside a box (ie. inside a cabinet), it is difficult to avoid the over spray problem. I will usually lightly sand with either a green or gray scotch brite pad and buff with paste wax.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2322 days
#4 posted 12-22-2011 06:55 AM
Did you add retarder to the mix, in order to slow down the drying so that overspray melts into the rest of the finish?
Or is this from a can?
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
