Chamfer or Bevel
Forum topic by Don Carrier posted 12-20-2011 02:02 AM 1208 views 0 times favorited 7 replies Add to Favorites Watch
View Don Carrier's profile
Don Carrier
114 posts in 2369 days
12-20-2011 02:02 AM
Topic tags/keywords: question cherry tablesaw router shaping shaker
I don’t know which term from the subject line is correct but I need help. I just finished a glue-up of the top for a nice cherry cabinet. It’s about 30×28 inches. I would like a nice low angle bevel on the edges. I’m fairly new at this, so I searched the forums thinking table saw. The whole left tilt right tilt thing made my head hurt. And after a recent serious tablesaw injury there are no taking chances situations in my future. Now I’m thinking router.
What do you guys, the pros, do? It’s a 3/4 top and I’d like a nice angle of the edge.
Thanks ahead of time
Don
-- Don
7 replies so far
View SASmith               's profile
SASmith
1850 posts in 2980 days
#1 posted 12-20-2011 02:06 AM
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_chamf.html
They have angles from 15-45 degrees.
I typically use a 45 degree chamfer.
-- Scott Smith, Southern Illinois
View ksSlim's profile
ksSlim
1275 posts in 2883 days
#2 posted 12-20-2011 02:08 AM
Handplane. Draw a couple of reference lines and then plane to the lines.
-- Sawdust and shavings are therapeutic
View Don W's profile
Don W
18707 posts in 2561 days
#3 posted 12-20-2011 03:02 AM
ditto on the hand plane. Plane the end grain first, then anything split on the sides will get taken off when those get planed.
Smitty_Cabinetshop
15341 posts in 2611 days
#4 posted 12-20-2011 03:14 AM
Triple ditto re: the handplane. But, I’m not a pro.
404 - Not Found
2544 posts in 2962 days
#5 posted 12-20-2011 03:20 AM
A beveled panel raising bit might do it in a router table if you don’t want to saw or plane it
View SnowyRiver's profile
SnowyRiver
51457 posts in 3473 days
#6 posted 12-20-2011 03:40 AM
You could easily do the bevel with a table saw or router. Since the top is probably square or rectangular, I would opt for the table saw. If you have a left tilt blade, simply run the piece on the left side of the fence with the top of the piece up or downdepending on what side you want the bevel. If its a right tilt blade, move the fence to the other side (left side) of the blade and do the same…top up/down…this way the cut off piece is under the blade rather than the entire board.
-- Wayne - Plymouth MN
Don Carrier
#7 posted 12-20-2011 03:46 AM
Thanks guys. I’ll see if I can get my hands on a router bit. I’m sure a hand plane would work great but I have no time to learn, as this is a christmas present. Moving the fence on the table saw is not an option. i’m a right tilt with not enough room. And that issue alone could turn this question into war and peace.
-- Don
