Increased rpm = increased cfm?
Forum topic by AKAndrew posted 12-20-2011 01:28 AM 887 views 0 times favorited 2 replies Add to Favorites Watch
View AKAndrew's profile
AKAndrew
53 posts in 2742 days
12-20-2011 01:28 AM
If you spin the impeller faster by adding a pulley, does it increase the cfm?
2 replies so far
View Brickman's profile
Brickman
51 posts in 2338 days
#1 posted 12-20-2011 02:00 AM
And if you get outside the intended CFM range the impeller will start to stall and you will actually decrease intake performance. This is a common problem in diesel trucks when you start modifying them. You get outside of the turbo’s designed pressure map and start to have turbo stall.
-- Mark - Pueblo, Colorado
View Maniteee's profile
Maniteee
7 posts in 2638 days
#2 posted 12-20-2011 02:25 AM
From my Navy days
Pump (Fan) Laws:
Flow is proportional to Speed
Flow is proportional to Headloss squared(Friction or Drag… pressure drop)
Flow is proportional to Power cubed
So if you double the flow you use 8 times more power.
-- Chris, Canterbury, CT
