Wards powrkraft RA saw
Forum topic by jimmac posted 12-20-2011 12:07 AM 3546 views 0 times favorited 15 replies Add to Favorites Watch
View jimmac's profile
jimmac
9 posts in 2315 days
12-20-2011 12:07 AM
Topic tags/keywords: saw wards radial switch
My Wards radial arm saw died in the middle of a project. The trigger switch went kaput and now I’m stuck till I get it replaced.
Does anyone out there have a trigger switch for the Wards TPC-2610C radial arm saw? The switch part number is
18-00205 (per parts list).
If no switch is around perhaps somone has a suggestion on another way to fix the on-off problem. I could by-pass the switch and just plug the saw into the wall, but that is not a smart way to go with a radial saw.
I did take the switch apart but it is beyond repair. After all the saw is about 45 years old, and I bought it new.
jimmac
-- James Mack
15 replies so far
View Pimzedd's profile
Pimzedd
598 posts in 4107 days
#1 posted 12-20-2011 12:17 AM
Why don’t you get a safety power switch from Rockler or Woodcraft and wire it in? Go to http://www.rockler.com/product.cfm?page=17401&filter=switch. That will give you the paddle to hit in case of an emergency. And they are on sale now at Rockler. I have one that I use on an old Craftsman bandsaw and it works well.
-- Bill - Mesquite, TX --- "Everything with a power cord eventually winds up in the trash.” John Sarge , timber framer and blacksmith instructor at Tillers International school
10253 posts in 3612 days
#2 posted 12-20-2011 12:48 AM
have you opened the switch and looked over its working
parts? Sometimes these things are easily fixed with a little
investigation.
View Don W's profile
Don W
18685 posts in 2532 days
#3 posted 12-20-2011 01:51 AM
worst case just throw a light switch on it until a proper switch arrives.
View Clouseau's profile
Clouseau
57 posts in 2997 days
#4 posted 12-20-2011 09:05 PM
1. Is there a number on the switch. The switch looks to be common “Skill Saw” switch. You might find a cross reference with Google.
2. Wire around it and use a power strip with a switch as part of it.
3. Purchase the switch mentioned above.
4. Make up a new switch box and mount it under the front of the table where is easy to reach. I use the 110-220 volt version from Grizzly ($13) in a 4×4 box with a plaster ring. Cut and wire in a new 14 ga extension cord so you have use of both plugs. You can then unplug the saw from the switch when the extra measure of safety is needed or when you need it temporarily for another machine. When wiring for 110 volts just use one side of the switch. If you burn out the contacts in the future, just move the wires to the other side.
-- Dan Coleman, retired Welding Inspector and past IA Teacher
View johnm59's profile
johnm59
1 post in 2300 days
#5 posted 01-02-2012 06:09 PM
Try this place. My father-in-law had the same problem a year or two ago and was able to get the switch from them. The web site is www.toolkraft.com but it only has contact info so you either have to call or email them. Good luck.
jimmac
#6 posted 01-03-2012 06:00 PM
Thanks for all the suggestions. I too found the powrkraft web site and have ordered the replacement trigger switch. I do not know when it will arrive as they are open only 2 days a week and now my check seems to have been delayed or lost in the mail.
jimmac
-- James Mack
View TexAcoon's profile
TexAcoon
8 posts in 867 days
#7 posted 12-06-2015 12:21 AM
I have a question about the wiring …. I recently purchased Kraft Model TPC 2610C and the switch was removed from the handle by the previous owner. When I got it home … and removed the handle … There were four wires in the handle open … White – Black – Red – Red …
My question is how this was originally wired? ... is there a brake on the motor for this particular saw that has to be energized do to the other set of wires …
Either way I just need help identifying the wires so I can wire this unit back together … Thanks!
View Woodknack's profile
Woodknack
11479 posts in 2344 days
#8 posted 12-06-2015 05:58 AM
Tex, you should start a new thread for your question.
MrUnix
6586 posts in 2163 days
#9 posted 12-06-2015 06:35 AM
Yup, start a new thread… but in the meantime, test for continuity between the white and black wires and the ends of your power cord… more than likely, the two reds are going to the motor, the black and white wires are coming from the wall, and the switch was a double pole type that switched both the hot and neutral.
View oldnovice's profile
oldnovice
6759 posts in 3332 days
#10 posted 12-06-2015 06:36 AM
+1 for Pimzedd soution!
That way you don’t have to worry about future old part replacement.
View dhazelton's profile
dhazelton
2755 posts in 2261 days
#11 posted 12-06-2015 01:29 PM
You sure it’s the switch and not the start capacitor? Did you wire the motor directly to a cord and plug it in? If it is the switch I would have wired in a new box with a paddle switch as suggested.
TexAcoon
8 posts in 867 days
#12 posted 12-06-2015 02:09 PM
Per request: Started new thread on this …
Figured I would ask questions up front before I started to obtain ideas from others…
MrUnix: will check the continuity between cord and switch wiring.. dhazelton: I checked the switch it was good …. I have not tried starting the saw since I got it… will do so today. Did not check capacitor. Will do so if the saw does not start…
Thanks guys for the input… When the other post is approved I will attach it to this post..
View Mcguyver's profile
Mcguyver
2 posts in 177 days
#13 posted 10-26-2017 01:04 AM
Hello, guys. I own two of this machine and am very familiar with this RAS.
And I do have an exra trigger switch to fit inside the handle assembly.
Even though you might buy a similar switch for Skilsaw, it would not work for all the functions.
If you need a replacement switch, just let me know. It’s $30 + S/H.
oldnovice
#14 posted 10-27-2017 03:31 AM
In case nothing else works, you can always use a toggle switch, even a wall switch will do in a pinch.
This is a high power motor control switch from Eaton (there are many other sources too)!
Or try the vintage machine place
Mcguyver
2 posts in 177 days
#15 posted 10-27-2017 07:23 PM
