If you read "The fine art of cabinet building" buy James Krenov you will find that was his original recommendation for the krenov style plane. Its how I built this one.
If you look at picture 4 you can see where the blade was cut at about 4" and you can see the cap iron screw groove.
I can post a more detailed picture of the blade if you need it.
You are in control of your destiny. You can make it whatever angle you would like. Generally, you are looking at 45 degrees. If you do a lot of work in wood with difficult grain, go up to 50ish. You can also make a scraper plane up in the 85-90 deg range. I don't suggest going to the low angle in wood. It just gets too thin to support the iron well.
The throat is also up to you. You want to get it to the point where it won't hold too many shavings so they flow out well. You want it big enough to get your fingers in to clear it when needed. You want the mouth well supported so it doesn't start chipping out.
What I have done on mine:
I went ahead and made the the front angle about 50 degrees. I then glued in the front block closer to make the mouth too narrow for the iron to come out. When the glue was dry, I opened the mouth with a file which left a blunt edge on the back of the front block instead of a thin knife edge. Several planes later, no problems with any of them and they all work just fine.
Get your blades from Hock Tools. They will make a huge difference in the quality of cut. Ron Hock will steer you in the right direction in terms of which blade to get. http://www.hocktools.com/
You'll want a thicker blade for a wooden plane than for a metal one - there's plenty of old Matherson blades on eBay if you take a look there.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
