Owners of Grizzly G0715P
Forum topic by MashMaster posted 12-19-2011 07:26 PM 1294 views 0 times favorited 6 replies Add to Favorites Watch
View MashMaster's profile
MashMaster
134 posts in 2747 days
12-19-2011 07:26 PM
I just purchased one and am waiting for delivery. I saw multiple good reviews of the saw here so I’m pretty confident with my decision. For owners of the saw, do you have any setup or operation tips for the saw? I’m coming from the world of contractor saws.
-- - Dave ; Austin, TX
View gfadvm's profile
gfadvm
14940 posts in 2777 days
#1 posted 12-20-2011 04:36 AM
I have that saw and like you was upgrading from a cheap contractor saw. I cleaned all the rust preventive off with mineral spirits then followed the manual TO THE LETTER and had no problems setting it up. Been in use for 11 months and I’m still very happy with it. Get a decent blade. I have never even tried the blade that came with it. The red Diablo blades have been really good to me (from Home De
MashMaster
#2 posted 12-20-2011 05:14 AM
Thanks, I have a few decent Freud blades so hopefully they will work well for me. What tooth count do you use?
Where do you notice the biggest difference between your old saw and the new one?
gfadvm
#3 posted 12-20-2011 06:38 AM
I use the 24 tooth the most but also use a 40 tooth. My 24 tooth Diablo rip blade seems to crosscut as cleanly as the 40 tooth. The biggest difference in performance is power and MUCH quieter. My favorite difference is the increase in space between the front of the table and the blade. My miter gauge now gets used a lot whereas I couldn’t use it on stock wider than 4” on the contractor. I have glued up a lot of rip cuts without jointing the edges which was a big difference.
View RonGoldberg's profile
RonGoldberg
44 posts in 2445 days
#4 posted 12-20-2011 01:29 PM
I bought the saw about 8months ago and love it. Biggest issue was getting it into my basement shop, but that is what “gym friends” are for. Great saw, fence is good. Only issue I had/have is that my Freud Dial-a-dado set is very, very hard to fit on the saw. If I knew it was going to be such a problem, I would have purchased the Jet Proshop saw.
MashMaster
#5 posted 12-20-2011 06:11 PM
Thankfully it is going into my garage so it should be easy to get in. I’m assuming the lift gate fee will extend to him rolling it the extra 20 feet to the garage.
Why is it hard to get the dado set in? Is it an 8” or 6” dado set?
View knotscott's profile
knotscott
8103 posts in 3462 days
#6 posted 12-20-2011 06:58 PM
Ron – Have you tried using a little light sanding with fine sandpaper on the bore of your dado set?
