Needing countertop material, meat dept. food grade type...smaller pieces
Forum topic by Chris posted 12-19-2011 06:50 AM 2508 views 0 times favorited 7 replies Add to Favorites Watch
View Chris's profile
Chris
358 posts in 4050 days
12-19-2011 06:50 AM
I am looking for the meat department, food grade type countertop material. Not sure what this material is or where i could possibly find a couple of pieces for a project. I need about 14” of it and would glue up to a thickness of about 2”.
If anyone is familiar with where i might find some of this type of material, please advise.
Chris
-- Chris Harrell - custom callmaker "Quacky Calls" Eastern NC. http://www.quackycalls.com
7 replies so far
View crank49's profile
crank49
4030 posts in 2935 days
#1 posted 12-19-2011 07:03 AM
McMaster Carr.
http://www.mcmaster.com/#polyethylene-plastic-sheets/=ffbh9s
It’s high density polyethelene.
If you need it for lubricity, like for a guide, use the ultra high molecular weight polyethelene (UHMWPE)
View interpim's profile
interpim
1170 posts in 3422 days
#2 posted 12-19-2011 07:31 AM
I worked in a meat department years ago… all of our countertops were stainless steel. For any type of plastic material, I use this place here in San Diego. http://www.sdplastics.com/
Oh, and the material you’ll want for food grade use is located here. http://www.sdplastics.com/hdpesheet.html
-- San Diego, CA
crank49
#3 posted 12-19-2011 08:18 AM
I just noticed you said you planed to “glue up” to a thickness of 2”.
Not with polyethelene you won’t.
There is no glue on this planet that will stick to polyethelene.
But, with deep enough pockets, you can buy it in 2” thickness.
View IrreverentJack's profile
IrreverentJack
727 posts in 2807 days
#4 posted 12-19-2011 02:46 PM
Chris, You might be thinking of Corian or some other solid surface material. -Jack
Chris
#5 posted 12-19-2011 03:29 PM
Oh, ok i didn’t realize you couldn’t glue this polyethylene. That is the material that i was thinking of, i just have not worked with any of it other than turned some smaller pieces on a lathe. It turns fairly well with scrapers, i just thought that i might be able to glue it together perhaps. Oh well.
Jack, i am familiar with Corian, not what i am wanting here. I am looking that white polyethylene as Crank expounded upon for a lathe project.
Oh well. i’ll just look around to see if i can locate some about 2” in thick, thanks guys.
Chris
View Bertha's profile
Bertha
13521 posts in 2657 days
#6 posted 12-19-2011 03:59 PM
^you can glue polyethylene but as soon as you touch it, it’ll separate;) As mentioned above, SD plastics will have it in white or black but it’s going to be pretty expensive. I looked into this for my bandsaw fence build and it was cost prohibitive. Good luck!
Natural (FDA Approved) Smooth 1/16” – 3” 48” 96”
1/16” – 3” 48” 120”
1/4” – 2” 60” 120”
Black Smooth 1/8” – 3” 48” 96”
1/8” – 3” 48” 120”
1/4” – 2” 60” 120”
View casual1carpenter's profile
casual1carpenter
354 posts in 2439 days
#7 posted 12-19-2011 04:37 PM
Chris, was looking into high density polyethylene for use on assembly bench-top, but abandoned that route for other reasons but here is one source, http://www.thecuttingboardfactory.com/
I thought there was mention of a glue specific for polyethylene, the people there could tell you.
Hope this helps, if not for a supplier then as a knowledge base, the guy I talked to on phone was knowledgeable about his product and customer friendly.
