Using epoxy
Forum topic by Betsy posted 12-19-2011 05:26 AM 1549 views 0 times favorited 14 replies Add to Favorites Watch
View Betsy's profile
Betsy
3391 posts in 3890 days
12-19-2011 05:26 AM
I want to start adding a little splash of color into some of my boxes and maybe into a few cheese boards along the way. The West epoxy system seems to get a lot of good results, but if you are not going to do a lot of epoxy work – would your general, buy it at the big box store, epoxy work?
Also doesn’t the epoxy and color seep into the surrounding areas where you don’t want it – how do you avoid that? I’ve not found anything on that one part – does it just sand off (the part that is not in the recess)?
Thanks in advance.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
14 replies so far
View JoeyG's profile
JoeyG
1275 posts in 2620 days
#1 posted 12-19-2011 05:39 AM
I tried the two part that is in the double syringe. I believe it was loctite. It didn’t work. It never fully cured to a hard surface, stayed kinda rubbery. It wouldn’t sand at all. That is the only thing I have tried besides the system three. System three 5 min epoxy works great for me. I have not had any problems with it hardening. I always wait 24 hours or so before sanding. I bought the smallest bottles they had cost between 15-20 bucks and still have 2/3’s of both bottles left after all the projects I have done.
-- JoeyG ~~~ http://www.facebook.com/JHGWoodWorks
JoeyG
#2 posted 12-19-2011 05:48 AM
I hear the casting resins have less air bubbles, which is the only grip I have about epoxy. I have mixed all kinds of stuff. In my blog, I was using acrylic paint, and inlace dye. I have used polyacrylic on epoxy with no problems
View thebigvise's profile
thebigvise
191 posts in 2895 days
#3 posted 12-19-2011 05:53 AM
I would go with West Marine. It sells for $40 per quart, which seems like a lot, but I just finished the quart purchased in 2008. Performance carries the day and I am not worried about a few cents cost premium. West always works as specified on the label.
-- Paul, Clinton, NC
Betsy
#4 posted 12-19-2011 05:54 AM
Thanks guys this gives me some ideas. We have a large craft store nearby so I’ll drop in to see what they may have. I don’t see myself doing a lot – but I have a few boxes in mind for this winter’s work that I think some nice inlay work would look nice.
Thanks again.
JoeyG
#5 posted 12-19-2011 01:47 PM
Good luck Betsy, and let us know what you come up with. Always interested in new ways to do things.
Betsy
#6 posted 12-19-2011 04:06 PM
Thanks Joey, I will.
View wingate_52's profile
wingate_52
224 posts in 2564 days
#7 posted 12-19-2011 04:57 PM
Have you considered Inlace?
View Chris 's profile
Chris
1879 posts in 3985 days
#8 posted 12-19-2011 05:10 PM
I have used System Three five minute epoxy with great results on everything from an Garden bench to voids in a bowl blank I was turning. It curred hard and was easy to sand away what you didn’t need.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View Lee Barker's profile
Lee Barker
2170 posts in 2845 days
#9 posted 12-19-2011 07:08 PM
Grizzly carries some epoxy stuff. This one intrigued me, though I haven’t tried it. I used their previous (similar, I assume) product with good results.
The bubbles are a problem, because epoxy should be very well mixed. Even if I’m doing one little knothole with 5 minute stuff, I’ll stir it for a full minute. So now we’ve got the maximum performance from the adhesive, but the bubbles are usually there.
Kindly,
View Jim Finn's profile
Jim Finn
2656 posts in 2916 days
#10 posted 12-22-2011 05:39 AM
I have used a finishing resin called “Z-Poxy” with good results. I add powdered chalk for color. I get the Z-Poxy at a hobby shop that sells Flying model airplanes.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
Betsy
#11 posted 12-22-2011 06:54 AM
Thanks for the replies guys. I’ve actually used inlace a couple of times on pen projects. It seems kind of expensive for some projects like what I’ve got in mind. I’ve not heard of “z-poxy” so I’ll have to check that out also.
CR1 – I’m confused (which is not unusual :-) ] but what do you mean “put a vacuum on it”?
View Bill White's profile
Bill White
4928 posts in 3955 days
#12 posted 12-22-2011 05:40 PM
http://www.youtube.com/watch?v=3WCz_zBgZko&feature=related
Found this yesterday. There are several postings about epxoy. Products are Australian, but some cool tips and ideas. Check it out.
Bill
-- bill@magraphics.us
Lee Barker
#13 posted 12-23-2011 05:37 PM
I used some System Three T-88 yesterday on a tool repair. I mixed in some sawdust for color and gave it a thorough stirring. No bubbles!
This is long cure stuff—open time, 45 minutes—so it wouldn’t be ideal for quick filling of knotholes and that sort of thing that one tends to do on the fly.
I notice that Grizzly sells a West Marine product that is 5 minutes. I’ll be curious to find out if it, like this quality product, responds to Popsicle stick turbulence different from the drug-store line of 5 minute stuff in the tiny tubes.
Kindly,
Betsy
#14 posted 12-24-2011 04:20 AM
Cr1 I would be interested ib seeing your set up.
Geez I has no ides there were so many choices in epoxies. Looks like I’ve got some experimenting to do to see what will work for me.
Bill thanks for the link.
