Router exclusively for table use
Forum topic by interpim posted 12-19-2011 04:34 AM 1808 views 0 times favorited 20 replies Add to Favorites Watch
View interpim's profile
interpim
1170 posts in 3694 days
12-19-2011 04:34 AM
hey folks,
I want to get a router strictly for table use, and I plan on building an extension on my table saw to house this router. The list of routers out there are quite extensive, and to be perfectly honest, I haven’t really had much luck wading through the tons of information yet.
So, as far as requirements go, here is what I think I need.
at least a 1/2 inch collett (since all my current bits are 1/2”)
at least 2 1/4 HP.
fairly lightweight. I don’t want to bend my T/S rails
Something easy to adjust the height on
Oh, and last but not least. I would like to keep it at around $200.
So, with the power of LJ, I’m sure i’ll get a ton of excellent recommendations. Thanks
-- San Diego, CA
20 replies so far
View Al Killian's profile
Al Killian
85 posts in 2861 days
#1 posted 12-19-2011 04:45 AM
Here is what I use in my router tables. They are haevy duty and are easy to adjust. http://www.cpomilwaukee.com/milwaukee-5625-20-3-1-2-max-hp-fixed-base-production-router/miln5625-20,default,pd.html?start=7&cgid=milwaukee-routers
-- Owner of custom millwork shop
interpim
#2 posted 12-19-2011 04:50 AM
LOL, I was actually looking at that model Al. I found it for $260 on Amazon, but was waiting to see what was recommended here before I made a final decision.
-- San Diego, CA
View HorizontalMike's profile
HorizontalMike
7770 posts in 3150 days
#3 posted 12-19-2011 04:55 AM
The only ones you are going to get under that $200 range would probably be the Triton 2 1/4 and 3 1/4hp routers SINCE THEY HAVE THEIR OWN LIFTING MECHANISM. Other than that, you could easily spend $200-$400 just on a decent lift, without getting the router. Just my 2-cents.
View knotscott's profile
knotscott
8174 posts in 3611 days
#4 posted 12-19-2011 05:04 AM
The most powerful 15 amp 3-1/4hp table routers are best suited for spinning bigger bits, but will weigh most. If that weight bends your saw’s rails, I’d consider getting a different fence.
Woodcraft has the Bosch 2.25 HP Electronic VS Router with Router Table Base on sale for email subscribers.
Item #153674 Regular Price $249.99 Sale Price 179.99
Just for reading your EMAIL you get a jump on next months sale and just in time for Christmas.
AND If you purchase before Christmas we will give you TWO 10 piece sets of Painters Pyramids item #148416 to help you finish your next project or put in a stocking.
OVER $70.00 IN SAVINGS
Quantities are Limited
This discount applies to E-Mail subscribers only. Print this page or show it to us on your phone to receive special pricing. Cannot be combined with any other discount or offer. Cannot be used for prior purchases. Offer valid only at independently owned and operated Woodcraft of Rochester. While supplies last.
As always Thank-You for your business
S. Clayton, Owner & Operator
Serving Rochester Woodworkers for over 10 Years Check your email tomorrow for the
Next Countdown to Christmas sale item
AND ONLY FOR E-MAIL SUBSCRIBERS
interpim
#5 posted 12-19-2011 05:16 AM
thanks for the input Mike, and the sale info Knots.
-- San Diego, CA
Craftsman on the lake
2843 posts in 3673 days
#6 posted 12-19-2011 05:37 AM
I have a dedicated 3 1/4hp triton and find that it meets my needs. Built in lift. If you can say one thing about it is that it’s almost a shaper. Seems extremely powerful. Nothing slows it down.
117417 posts in 3813 days
#7 posted 12-19-2011 05:45 AM
Depending what your routing you can use a Porter Cable 690 it’s not heavy duty but I used one for years with out problems.
View Loren's profile
10477 posts in 3884 days
#8 posted 12-19-2011 05:46 AM
The fixed-base Milwaukee body-grips adjust through the bottom
with a ball-end hex wrench. It’s a shame to dedicate such a fine
topside router to table use only, but the feature is there.
Another alternative is to just buy a motor and figure out some
alternate means of raising and lowering it.
interpim
#9 posted 12-19-2011 05:51 AM
I did see an article recently in a woodworking magazine that discussed how to build your own router lift with tabletop adjustment for just the motor. I haven’t seen anyplace selling just the router motor, where might one find those?
-- San Diego, CA
View BurtC's profile
BurtC
103 posts in 3366 days
#10 posted 12-19-2011 06:20 AM
Give the Bosch 1617 a look. I use one in a table with the fixed base which also has the top side micro-adjust. http://www.amazon.com/Bosch-RA1165-Under-Table-Router-Above-Table/dp/B0007VHPFK/ref=sr_1_3?ie=UTF8&qid=1324268530&sr=8-3
#11 posted 12-19-2011 06:25 AM
ebay.
View Guss's profile
Guss
94 posts in 2677 days
#12 posted 12-19-2011 04:37 PM
I have the 3 1/4 horse Triton. Its a great router lots of power built in lift with above table crank. It also has a spindle lock so you only need one winch to change the bit. the only compliant that i have is the power switch on the router has to be in the off position to change the bit
View richgreer's profile
richgreer
4541 posts in 3310 days
#13 posted 12-19-2011 04:57 PM
A few years back, I wanted a router that would be dedicated to a router table and my criteria was much like yours. I choose a fixed base Porter Cable 890 and I have been very happy with it. You can adjust height from above the table, although I found its fine tuning capabilities lacking.
Another thought – - You may not want it now, but someday you may want to get a router lift. I did (now I can really micro adjust the bit height). Router lifts are only available for certain brands and models. I advise getting a router that you are confident can be used in a router lift in the future. The PC 890 is one that qualifies on this criteria.
View Bertha's profile
Bertha
13551 posts in 2929 days
#14 posted 12-19-2011 04:57 PM
^I’m with the guys above: Triton 3+. The price is right, it’s too big to be of practical use above the table (at least for me), and it’s got above-the-table height adjustment. You’ll probably have to drill out your router plate for the crank, but no big deal. I’ve had zero problems with mine.
404 - Not Found
2544 posts in 3205 days
#15 posted 12-19-2011 05:38 PM
Whichever way you go, look for one with a decent plunge depth and variable speed. I can’t fault my DW625, 80 mm plunge depth and there’s a fine height adjuster for it too.
