DeWalt DW735 Planer - What Am I Doing Wrong?
Forum topic by DillingerWhiskey posted 521 days ago 3133 views 0 times favorited 53 replies Add to Favorites Watch
View DillingerWhiskey's profile
DillingerWhiskey
11 posts in 1143 days
521 days ago
I purchased the Dewalt DW735 Planer and it set up real quick. I have a ton to old growth oak planks that I cut down to 4/4 boards. This oak is 100+ years old from an old barn. Its clean no nails. I took five small 3” wide boards about 30” long and put them through. The surface was like glass. GREAT! The next day I stepped it up and put through a 9” oak board only 30” long. They too came out nice. I took my time and was doing very small cuts. Much less than 1/16th inch. The very next board, of the same size it hesitated for 1/10 of a second but it finished the cut. After about the 5th pass the in-feed rollers started to slip more and more and it got to the point that they would not feed at all unless I pushed the board in REAL hard and then pulled it out the out-feed side. I thought it was defective. I took it back and exchanged it. Second time, the Same problem in about the same number of boards. This can not be the blades as it gets hung on the in-feed rollers before it even gets to the rollers. I backed the cutter head off so it was not making a cut and it would still hang up. I got a piece of pine it still hangs up. I carefully examined the rollers and they look fine. I looked all over this site and other sites and no one is having this problem…so what am I doing wrong…any assistance would be appreciated.
53 replies so far
View ShaneA's profile (online now)
ShaneA
3964 posts in 767 days
#1 posted 521 days ago
When it gets colder, the rollers tend to grip less and are effected by dust and debris. Raise the machine and clean table and rollers, and then give it a try.
View Tim's profile
Tim
1292 posts in 1734 days
#2 posted 521 days ago
Do you have in-feed and out-feed tables? If so, are they properly adjusted?
Also wax the table.
View ajosephg's profile
ajosephg
1719 posts in 1730 days
#3 posted 521 days ago
It seems to me that old wood gets harder and harder making it more difficult to machine.
Assuming that your rollers are turning the only corrective action I can think of is to clean the rollers and wax the table. I think rubbing alcohol works, but check your users manual first, and be careful you don’t cut yourself.
Edit: I just thought of something else I’ve heard of. Get a spray bottle and lightly spray the top surface of the board with water.
-- Joe
View HorizontalMike's profile
HorizontalMike
4931 posts in 1083 days
#4 posted 521 days ago
FWIW, I use isopropyl alcohol to clean the rollers on my 13in Ridgid planer and that helps a lot. Just remember to unplug the machine any time you are reaching in there. ;-)
View HerbC's profile (online now)
HerbC
778 posts in 1028 days
#5 posted 521 days ago
Get some SlickStrips material and coat the bed of the planer with it. That will greatly reduce the friction between the lumber and the planer bed and should help a lot. I have noticed though that the lunchbox portable planers can’t effectively take a very big bite each pass.
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Jim Finn's profile
Jim Finn
1062 posts in 1091 days
#6 posted 521 days ago
I also have that planer…....wax the bed!
-- In God We Trust
View lew's profile (online now)
lew
8984 posts in 1924 days
#7 posted 521 days ago
Ditto what Jim said.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View WDHLT15's profile
WDHLT15
686 posts in 645 days
#8 posted 521 days ago
Wax often!
-- Wood-Mizer LT15
View lenb's profile
lenb
46 posts in 521 days
#9 posted 521 days ago
I also purchased that model planer and I was IMPRESSED WITH ITS PERFORMANCE
HOwever it was short lived as I also am pushing tne boards through, so I took the blades and the board to the dealer and all he could see was the edge is gone of the blades !!!dah They have only done several short boards!!! All he could suggest was a new set, I think they sell the machine with very poor quality blades and as I was leaving they tryed to sell me a higher quality blade. So I will get these sharpened but \Ithink I will have to spend another $100.00 or so on good blades !!
-- Profile photo is of our big 50th celebration, What a great day that was, July 2011
View gfadvm's profile
gfadvm
6635 posts in 859 days
#10 posted 521 days ago
Old/ reclaimed wood that is dirty will kill planer blades very quickly as the dirt is really grit just like sandpaper. I try to always wire brush and then blow clean with an air gun. A pain but it beats trashing blades. I have heard others say that the standard DeWalt planer blades were poor quality???
DillingerWhiskey
#11 posted 521 days ago
Thanks for all the quick replies! I’ll try the cleaning and wax as suggested. Does it seem strange to anyone that this common problem exists in the first place? I examined the rollers and they are 99% clean. Just very minor pieces of dust. I may have to reconsider this unit as I have very long pieces 13’ that may dirty the rollers half way through the piece. I’ll be doing more cleaning than wood working?
View juniorjock's profile
juniorjock
1774 posts in 1935 days
#12 posted 521 days ago
Clean the rollers…..that’s all there is to it. . . . . and you’ll probably have to do it again, and again…. and….
edit: one of those micro-fiber cloths work great.
gfadvm
#13 posted 521 days ago
Dirty rollers doesn’t sound right unless DeWalts are special. I have planed MILES of lumber with my Ridgid and never cleaned the rollers (and no problems so far).
ShaneA
#14 posted 521 days ago
The blades are reverseable, so you can flip them before buying a new set. This has only happened to me in the winter, low temp and low humidity will adversely effect the grip of the rubber. The planer should be fine.
View cam1297's profile
cam1297
59 posts in 1380 days
#15 posted 521 days ago
Having long boards and a short planer bed may cause the jam. try supporting the board on the infeed past 1/2 way then switch.
showing 1 through 15 of 53 replies
