1 hp HF Dust Collector
Forum topic by sawedoff posted 523 days ago 1902 views 0 times favorited 22 replies Add to Favorites Watch
View sawedoff's profile
sawedoff
120 posts in 590 days
523 days ago
Does anyone on here use this dust collector. I was pretty much sold on the 2 hp model but my space is very limited (half of a two car garage) and was thinking that the 2hp would take up some floor space. I will only be using one tool at a time and don’t mind changing the hose from one machine to the next.
Am I wasting my time with this? I am just trying to weigh all the options on DC’s before I pull the trigger…..... Even thought about trying to do it with my shop vac and using the dust deputy
-- still wet behind the ears.....
22 replies so far
View zindel's profile
zindel
229 posts in 820 days
#1 posted 523 days ago
I don’t have one…yet…but if you do search for HF dust collector here in LJ you will find that a lot of people have it and they for the most part will say that it is the best value DC you can get. However might i urge you to make sure you replace the bag with a canister as i think it comes with a 5 micron bag and that is not quite good enough for healthy working. But yes from what i have heard and read it is a very good DC.
-- If you can't fix it with a hammer, You've got an electrical problem.
View syenefarmer's profile
syenefarmer
332 posts in 1251 days
#2 posted 523 days ago
Have you considered the noise factor? IIRC those smaller 1HP HF dust collectors are quite loud, much louder than the 2HP.
sawedoff
#3 posted 523 days ago
If I decide to go with the 2hp model that is exactly what I was going to do. I am still a little curious about the smaller (1 hp) model. Either way I go I would use a chip separator
View BurtC's profile
BurtC
77 posts in 1300 days
#4 posted 522 days ago
If you are reffering to the small horizontal/portable one, yes I have this one. I put mine in a outsiide cabinet with exhaust just blowing out a dryer vent( no bag). There is only 10 feet of inside 4” duct, so it workes well for a single machine running. I still use a shop vac for smaller tools like handheld router and miter saw. Works well and would recommend with the above mentioned install. Hope this helps.
87253 posts in 1747 days
#5 posted 522 days ago
I have the 2hp and really like them,I mount mine outside.
View Stephenw's profile
Stephenw
240 posts in 556 days
#6 posted 522 days ago
I first purchased the little red one. Right out of the box, it was really loud and had a burning electrical smell. The motor used brushes. I took it right back to the store.
Now I have the green 1 HP model. It’s really quiet and I like it. The bag is 30 micron. It works well for me with a 2 1/2” hose. It is equipped with an induction motor.
-- http://www.garagebulletin.com/
View hairy's profile
hairy
1763 posts in 1702 days
#7 posted 522 days ago
This is the only pic I can find of the one I had. I had the hose going to a trash can with a separator lid. The can caught the chunks and the dust went into the bag. I would take the bag off, go in the back yard and turn it inside out and shake it to clean it.
This is the red harbor freight 1 h.p. It does work better than nothing, but hang on to your broom and dust pan.It’s not all that good. I believe the specs are over inflated.
I had a little over $150 in the whole deal buying everything new. Save your money and get a real dust collector.
-- It must be jelly baby, cause jam don't shake like that...
View crank49's profile
crank49
2288 posts in 1141 days
#8 posted 522 days ago
I bought the red 1 hp HF collector to build into the base of the router table I’m designing.
I got it for $50 with a coupon and on sale so my choice was this or a cheap shop vacuum.
I did not realize it had a universal motor (with brushes like a shop vac) till I got it, or I would have gone for the vacuum. Havent used it yet other than to turn it on an make sure it was not dead. Noisy as a vacuum.
I have the 2 hp HF collector for my other major power tools and it does a wonderful job.
If you can possibly make the room, the 2 hp is way more than twice as much machine.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
Stephenw
#9 posted 522 days ago
I posted a review of the Harbor Freight 31810 dust collector on my website…
http://shopngarage.com/2011/12/harbor-freight-31810-dust-collector/
View Lifesaver2000's profile
Lifesaver2000
463 posts in 1282 days
#10 posted 521 days ago
Nice review Stephenw. When you had the impeller out of the machine, did you happen to measure the diameter?
Stephenw
#11 posted 521 days ago
I didn’t measure the impeller when it was out. Based on the back of the housing, I estimate it at approximately 10 1/2 inches.
View Jimbo4's profile
Jimbo4
712 posts in 933 days
#12 posted 521 days ago
Stephenw – Saw your video, and I am sold! My Ridgid shop Vac that I have hooked up to my Onieda makes at least three times as much noise as the HF collector. Gonna go get me a Christmas present, and connect it to the Onieda.
-- *Arachnoleptic*: The frantic dance performed just after you've accidently walked through a spider web.
Stephenw
#13 posted 521 days ago
Rosebudjim, if you get it, let us know what you think. I was planning on getting the Oneida cyclone from Woodcraft to use with mine.
View bdjohns1's profile
bdjohns1
39 posts in 862 days
#14 posted 517 days ago
Just as a note, there are two different ~1hp HF dust collectors. The red one with the universal motor, and an olive drab one which runs off an induction motor – I’ve got that one. I’m still running it into a 5-micron bag, but I’m also mainly using it for chip collection off my planer that this point via a trashcan lid separator – shopvac + dust deputy is handling all of the actual fine dust.
I’ve got the parts I need (minus the canister filter) to add a Thien separator to turn it into a baby 2-stage unit. One of my “coming soon” projects…
-- Ben - resident cheese whiz.
sawedoff
#15 posted 517 days ago
Thanks for the reply Ben…..... I’ll be sending you a PM soon trying to get some details on your set up
