Filling Knot holes
Forum topic by PaddyBoy posted 12-17-2011 04:10 PM 1937 views 0 times favorited 4 replies Add to Favorites Watch
View PaddyBoy's profile
PaddyBoy
4 posts in 3557 days
12-17-2011 04:10 PM
I am finishing a live edged black walnut tabletop. There are 2 knot holes that are 2” in diameter and about 1” deep. A epoxy resin finish was requested. I am not a professional finisher, but from what I remember that seems too thick to pour. Can I pour multiple thin coats, or is there a better method?
View Alan Robertson's profile
Alan Robertson
66 posts in 4096 days
#1 posted 12-17-2011 04:38 PM
Make sure void does not go all the way through. If it does, seal off on under side with filler, dark cailk, tape etc. Fill it in steps to avoid heat build-up. Works for me. Good luck.
-- MrAl
View cathyb's profile
cathyb
828 posts in 3422 days
#2 posted 12-18-2011 10:18 AM
Mix your epoxy. Brush on a thin coat. Add sawdust. Use a thin strip of wood to push it into the voids. Don’t be stingy with the saw dust. Add more epoxy. Now you have a bit of a slurry. Completely fill the knot. Removed the excess epoxy from the surrounding wood with denatured alcohol. What a day. Sand. Beautiful!
-- cathyb, Hawaii, www.cathyswoodworking.com
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2532 days
#3 posted 12-18-2011 10:20 AM
you can also add rit dye (black) to color the knot holes so that they look more natural
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Bearpie's profile
Bearpie
2601 posts in 3195 days
#4 posted 12-19-2011 06:25 AM
You could also use turquoise or other rocks to fill with for accent!
-- Erwin, Jacksonville, FL
