White Pine for Work Bench
Forum topic by sawedoff posted 12-17-2011 02:44 AM 4277 views 0 times favorited 9 replies Add to Favorites Watch
View sawedoff's profile
154 posts in 2351 days
12-17-2011 02:44 AM
Hey Guys
I’ve got access to some pretty cheap lumber from a family member. He has white pine that is 8/4. I was wondering if I could make a good work bench out of that? I know pine is pretty soft but it is probably going to be close to free for the lumber.
Any thoughts or ideas would be great
-- still wet behind the ears.....
9 replies so far
View cutmantom's profile
401 posts in 2966 days
#1 posted 12-17-2011 03:01 AM
I think it would be too soft, but it would work of course, durability would be the issue
View Tedstor's profile
1643 posts in 2564 days
#2 posted 12-17-2011 03:08 AM
A quality hardwood bench, like maple, can last centuries.
White pine will only last for a few measley decades.
Yes, it will show wear faster than a hardwood. But from a functional standpoint, there’s nothing wrong with pine….especially 8/4 pine. I mean, entire homes are built from the stuff. I’d go for it.
View gfadvm's profile
14940 posts in 2621 days
#3 posted 12-17-2011 05:35 AM
My bench was originally made of 2×4 studs on edge and it worked well for several years then got pretty beat up so I covered it with 3/4” ply, used it a couple more years, and then covered it with white Formica which I’m currently very pleased with so YES pine will work.
View Sawkerf's profile
1730 posts in 2999 days
#4 posted 12-17-2011 06:10 AM
The pine will probably be ok for the framework of your bench, but I would use something harder for the top.
-- Adversity doesn't build reveals it.
View Brian S's profile
Brian S
108 posts in 2524 days
#5 posted 12-17-2011 06:27 AM
I think it will work fine. The price is certainly right.
At the very least, it will last several years. If you hate it then, you are only out your time, and you get the thrill of doing it again. You may want a different style by then anyway.
-- Brian
View Rob Drown's profile
Rob Drown
786 posts in 3764 days
#6 posted 12-17-2011 07:14 AM
The pine would work great for the legs and stretchers. You might want a hardwood for the top. dog holes in pine would elongate.
-- The expectations of life depend upon diligence; the mechanic that would perfect his work must first sharpen his tools. Confucius, 经过艰苦的努力的梦想可以成真
View TCCcabinetmaker's profile
932 posts in 2286 days
#7 posted 12-17-2011 07:22 AM
It’ll work, I’d just think of a different material for a top perhaps. OF course my home shop bench is only like 3/8ths plywood, simply because I never have gotten around ro replacing it… Just needed a bench in a hurry.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View Don W's profile
Don W
18661 posts in 2498 days
#8 posted 12-17-2011 08:41 PM
Up until about a year or so ago, all I had was pine benches. I’ve still got 2 that I use all the time. I made my “real” bench out of hardwood, but like you, it was wood I had. I’d say go for it. It will be around for a long time.
-- - Collecting is an investment in the past, and the future.
View benchbuilder's profile
284 posts in 2381 days
#9 posted 12-21-2011 03:50 AM
You could use the pine and build a torsion box top, covered with a quarter inch hard board that is replaceable and your workbench would last a very long time.
