Leveling Machines
Forum topic by zindel posted 12-17-2011 12:36 AM 2349 views 0 times favorited 11 replies Add to Favorites Watch
View zindel's profile
zindel
257 posts in 2848 days
12-17-2011 12:36 AM
Okay so 3 posts in 1 day…has to be a record for me today…ANYWAYS…I was wondering if anyone knows of a good way to level off their machines. I work in a garage and it slopes down and out into the drive way as it should…but that is no good for machines and tables in a work shop. I was thinking something along the lines of this…
but they don’t give a place to purchase or a price. Anyone else know if something useful? other then a block wood ;)
-- If you can't fix it with a hammer, You've got an electrical problem.
11 replies so far
View americancanuck's profile
americancanuck
422 posts in 2808 days
#1 posted 12-17-2011 01:00 AM
leveling machines is, quite simply, not imporpant unless you are dealing with machines that are not free standing. Get it as close as you can get it and call it good enough. bits and such have to be perpendicular to the table but level means very little.
-- Retired and lovin it
zindel
#2 posted 12-17-2011 01:02 AM
Sorry i guess level was not quite what i was going for…how about stable? lol i am gonna rearrange my shop and i know some places i want to put them they will tip around and not quite be all 4 on the ground…
Rick Dennington
6295 posts in 3392 days
#3 posted 12-17-2011 01:07 AM
Just use shims…..wood shims…...Usually takes about 1/4” thickness or less. place a shim under each leg, or as needed to get level…..
-- " At my age, happy hour is a crap and a nap".....!!
View hairy's profile
hairy
2782 posts in 3730 days
#4 posted 12-17-2011 01:08 AM
Each tool you want to level is probably different. Some things work in one situation that won’t in others. Take a look at how I leveled this. Angle iron and nut/bolt.
-- My reality check bounced...
View DBerryhill's profile
DBerryhill
5 posts in 2544 days
#5 posted 12-24-2011 04:38 AM
You can find inexpensive adjustable leveling pads similar to the ones in your photo here:
http://www.use-enco.com/CGI/INPDFF?PMPAGE=541&PMCTLG=00
http://www.use-enco.com/CGI/INPDFF?PMPAGE=542&PMCTLG=00
Most woodworking machines weigh less than metalworking machines so you can use the smaller (and less expensive) ones.
View doncutlip's profile
doncutlip
2832 posts in 3754 days
#6 posted 12-24-2011 04:47 AM
Yeah, I agree with Rick, just use shims; even with a nice mobile stand on my bandsaw I have to shim it.
-- Don, Royersford, PA
View GaryK's profile
GaryK
10262 posts in 4186 days
#7 posted 12-24-2011 04:58 AM
Leveling a machine is only really important for metal machining tools such as a lathe.
If they are twisted at all they won’t machine a perfect diameter from on length to the other.
On woodworking machines it is not nearly as important and like others have mentioned, shims work fine.
View Les 's profile
Les
201 posts in 2888 days
#8 posted 12-24-2011 02:58 PM
I just use shim shingles or if they are the right thickness a square of composition shingle. If you put the grit down it won’t move around.
Les
-- Stay busy....Stay young
View ScottN's profile
ScottN
261 posts in 2877 days
#9 posted 12-24-2011 03:51 PM
I’ve used carriage bolts before on an old table saw out feed table.
-- New Auburn,WI
View IrreverentJack's profile
IrreverentJack
727 posts in 3041 days
#10 posted 12-24-2011 05:03 PM
Lots of choices on Ebay. -Jack
zindel
#11 posted 12-24-2011 06:16 PM
Jack thanks for the link i will have to look through those. really helps!
