filling voids - sequence?
Forum topic by leeko posted 12-16-2011 11:55 PM 1393 views 0 times favorited 8 replies Add to Favorites Watch
View leeko's profile
leeko
15 posts in 2621 days
12-16-2011 11:55 PM
Hi all,
I’m making a chess board using maple and walnut, and am about to start finishing. I have a few voids in the walnut, and was initially going to leave them as is, for a more rustic finish. But, I decided I’d like to create a more glassy, polished look to the finish, so I’m planning to fill the voids with either CA glue or lacquer, and finish with lacquer. Pictures are below.
My question is: what would be the optimal sequence? Ideally, I’d like to just use the lacquer to fill the gaps (which look kind of like a brown peapod cut along its length. But, to get the really smooth finish I’m looking for, I’m planning to use a grain filler such as jasco. I’m guessing that the grain filler would get in the holes, and make a big mess?
In that case, should I try to fill them with CA glue BEFORE using the grain filler? I’m a little concerned about the CA glue staining the walnut.
Pic1
Pic2
Pic3
p.s. anyone know what these voids are called, or what causes them?
Thanks in advance for any advice.
Regards,
8 replies so far
View Jim Finn's profile
Jim Finn
2656 posts in 2915 days
#1 posted 12-17-2011 03:18 AM
Have you considered an epoxy to fill them with? I use a product called “Z-Poxy” to fill voids.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
leeko
#2 posted 12-17-2011 03:35 AM
I hadn’t thought about that -is there an advantage over CA glue?
View camps764's profile
camps764
867 posts in 2353 days
#3 posted 12-17-2011 02:55 PM
I’ve read a lot of folks using various epoxy’s to do the job. From what I understand doesn’t matter what kind of epoxy you use as long as it dries clear. I am using some reclaimed lumber in a project and plan to fill a lot of nail holes and voids with epoxy as well.
-- Steve
Jim Finn
#4 posted 12-17-2011 02:58 PM
What I like about Z-Poxy is that is actually an epoxy finishing resin and is thinner than other epoxy. Easier to work out any bubbles, in my experience.
leeko
#5 posted 12-24-2011 06:49 PM
Thanks for all the advice,
I’ll pick up some epoxy and get filling :)
leeko
#6 posted 12-31-2011 09:31 PM
Thanks everyone for the replies. I went ahead and filled with epoxy. It dried clear with only a few bubbles. I then used a card scraper to get it back level, but after scraping the epoxy is a dull gray colour – not clear anymore. It seems to clear up when wetted e.g. with naphtha, so I’m hoping when the finish is applied it’ll have the same effect!
Thanks,
View Al Killian's profile
Al Killian
85 posts in 2619 days
#7 posted 01-01-2012 02:53 AM
Them voids are from either insect damage or injury to the tree. For a filler I would go with walnut sawdust mixed with some blonde shellac. Once it dries it will be very close to the same color. From there use a coat of lacquer sealer followed by several coats of high gloss lacquer.
-- Owner of custom millwork shop
View Daver725's profile
Daver725
13 posts in 2329 days
#8 posted 01-03-2012 04:03 AM
I would agree with Al’s post if you want the imperfections less knowticable. If you want them to still be seen I would use the epoxy. I’ve had good luck using the sawdust method myself. Especially on oil finishes, using grain sealer and wet sanding it in.
Dave
-- Insanity, doing the same same thing over and expecting different results.
