Do I need a Jointer Plane?
« back to Hand Tools forum
Forum topic by 12strings posted 12-16-2011 04:45 PM 7864 views 0 times favorited 33 replies Add to Favorites Watch
View 12strings's profile
12strings
434 posts in 2412 days
12-16-2011 04:45 PM
I am a woodworker on a very small budget, and would like to spend my birthday money on a Larger plane to use as a jointer. I will be looking to spend no more than $100, so I’m looking at old stanleys. So Here’s my question:
Do I really need a No.7 or No.8? Or will a No. 6 Work almost as well?
There is a local antique market where I got a nice No.5 that I’m really happy with…they also have a No.6 Corrugated bottom that is pretty nice.
If I am preping small stock (for door frames, small tables, occasionally jointing edges) Can I get by using the No. 5 first, then the No. 6 for flattening, then a smoother?
O should I hold out and buy a No.7 or make a larger wooden jointer plane?
Thanks?
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
33 replies so far
View Brandon's profile
Brandon
4152 posts in 2979 days
#1 posted 12-16-2011 04:54 PM
My guess is that a #7 would be a good fit and I see them on ebay go for much under #100. I have a #6 and an #8 and I generally break out my #8 for jointing, but man is that thing heavy.
-- "hold fast to that which is good"
View Chris 's profile
Chris
1879 posts in 4019 days
#2 posted 12-16-2011 05:55 PM
My #5 is the most used plane in my arsenal. Having said that, here is what I normally do when prepping stock by hand.
1. With a cambered blade in my #5 I flatten across the grain checking for high spots created by cupping, twisting etc…
2. Using my old pre-lateral #8 I will take smoothing passes across the grain this finishes leveling the cross width
3. Use the #8 with the grain
4. Use a smoother with the grain.
I believe that a #5 or #6 along with a smoother can provide you the functionality you are looking for initially. It is nice to have multiple planes and blades setup to do the job as it can save you a bit of time.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View Dan's profile
Dan
3630 posts in 2908 days
#3 posted 12-16-2011 06:04 PM
I would hold out and get a #7. The 6 may work fine but if it was me I would start with the #7.
-- Dan - "Collector of Hand Planes"
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2383 days
#4 posted 12-16-2011 07:30 PM
To those of us who don’t have stanley numbered planes… I have no clue if you’re talking about the 18” jack, the 22” jointer or the 28” jointer….
What I can say though, in non-numbered speak :P Is that with jointing, the longer your (sole) or fence, the straighter the joint is. I’ve used my 18” jack on some 12’ hickory before and it took a bit more work than it would have with a 22” or even 48” jointer.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
10476 posts in 3676 days
#5 posted 12-16-2011 07:37 PM
The no. 7 is the one to get. No. 8 planes are real heavy.
You can make your own jointer plane easily enough. Once
you make a couple of planes you’ll think of it as an easy thing
to do.
View Bertha's profile
Bertha
13529 posts in 2721 days
#6 posted 12-16-2011 08:27 PM
I’ve got all of them and I probably prefer the #7 for 4/4 stock (what I generally use). The #8 will get things very flat but like Loren mentions, it’s very big and has a bit of a technique learning curve. It’s fairly easy to tip the plane. If you like the wide #6, though, you might actually prefer the #8. If I could only have 1 plane, it would probably be the #7.
12strings
#7 posted 12-16-2011 09:00 PM
I have actually made one wooden plane already, It works well enough to be a scrub plane or fore plane. I’m not really adept at setting the iron with a mallet yet, so I have trouble getting the exact depth of cut that I want, but I would definitely be willing to try again. I’m thinking of making one of beech or Cherry, or whatever else Menards has. Any suggestions?
I Just through I’d get this No.6 Stanley for $35 if I thought it would work nearly as well.
Bertha
#8 posted 12-16-2011 09:03 PM
^The #6 is tippy to me but it should handle most projects.
12strings
#9 posted 12-16-2011 09:07 PM
Also, for you non-stanley guys, the #6 is 18’, #7 is 22’ & #8 is 24”.
View drfunk's profile
drfunk
223 posts in 2705 days
#10 posted 12-16-2011 09:07 PM
I’m going to buck the trend here and say the 6 will work fine – especially if you are already working with dimensional lumber and small stock. If you are working rough cut lumber or especially long pieces then a 7 or 8 (or longer) makes sense. IMO even a 5 – if set up properly – makes a fine jointer on small stock. Since I only occasionally work with non-dimensional lumber I usually have my 5 set up like a jointer and the 7 & 8 rarely come out of their climate controlled hyperbaric chamber.
View wingate_52's profile
wingate_52
224 posts in 2597 days
#11 posted 12-16-2011 09:14 PM
I would go for a No.7. The 8 is long and heavy, You need a big bench to use it and somewhere to store it. No 7.
wingate_52
#12 posted 12-16-2011 09:15 PM
My Record no.7 with the end on.
View Don W's profile
Don W
18754 posts in 2595 days
#13 posted 12-16-2011 09:37 PM
A 6 would work,especially if you’re doing shorter work. That said, for gluing up panels I always grab my 8. I like the fact that its heavy. I have a 7 and would certainly use it more if I didn’t have the 8.
In theory, your 5 would work if you don’t have a camber on your blade. You just need to pay more attention to detail with a shorter plane. If you really want a plane for jointing, you really should get a #7 though. You won’t regret it and should be able to pick one up under $100 easily. I’ve bought 2 #7s, one for $35, and one for $45, one on ebay and one locally. Be patient and look, you should be able to get one under $50 that would need minimal restoring.
Brandon
#14 posted 12-16-2011 09:39 PM
Perhaps the question is which plane should you get next, because I’m sure you’ll eventually want all of the numbers. If you can get a decent #6 for $35, I’d say go for it. You can even probably find a #7 that needs a good cleaning for the remainder of your $100.
drfunk
#15 posted 12-16-2011 09:47 PM
Remember, a number 6 is only a short Chris Schwarz blog post away from being the best and most sought after plane in all the universe. (same with all the other planes he posts about)
showing 1 through 15 of 33 replies
