Removing wax from a dining table?
Forum topic by FMG posted 12-15-2011 03:03 PM 2259 views 0 times favorited 7 replies Add to Favorites Watch
View FMG's profile
FMG
65 posts in 3246 days
12-15-2011 03:03 PM
Topic tags/keywords: question
Hey all, Good to be back! Its been a while since I have been on here or even in the shop for that matter. I have a project and need a little help and or advice trying to remove wax and build up from our dining room table. I would like to attempt not to harm the original finish. If I am successful in doing so, what should I use to reseal the top? If I do wreck the old finish though what would be a good finish to use? The original finish looks similar to Minwax Early American, if I had to guess. It is a dull satin finish. I do have to match the color to our hutch and that could be a problem.
Thanks in advance everybody,
Rick
-- FMG- Woodworking is 90% mental the other half is physical
7 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2326 days
#1 posted 12-15-2011 03:44 PM
Give it a vigorous wash and scrub with naptha and gray nylon pad, followed by cleaning up with toweling. A couple iterations would be a good idea. Renew the finish by wiping on a naptha thinned oil poly: wipe on a coat, let it sit a bit, then wipe off. One coat a day for three days should do the job.
Clint
View ksSlim's profile
ksSlim
1274 posts in 2855 days
#2 posted 12-15-2011 06:15 PM
Murphy’s oil soap will cut thru the build up, followed by the solvent of choice.
-- Sawdust and shavings are therapeutic
View Bertha's profile
Bertha
13521 posts in 2658 days
#3 posted 12-15-2011 07:44 PM
I was going to say scraper plane and card scraper. Like Cr1 mentions, I bed there’s gunk impregnated into the surface.
117062 posts in 3542 days
#4 posted 12-15-2011 07:50 PM
I agree with Clint
Smitty_Cabinetshop
15280 posts in 2583 days
#5 posted 12-15-2011 08:02 PM
Jackhammer.
I have to think Clint’s approach is low risk, but if the naptha does affect the underlying color, as CR1 suggests, a total refinish would be in order. If it’s really minwax-type (mainstream) color, shouldn’t be a huge deal getting it to stay in line with your hutch. But you ‘knew the job was dangerous when you took it!’ Good luck!
View gfadvm's profile
gfadvm
14940 posts in 2655 days
#6 posted 12-16-2011 04:41 AM
I’ve had success with the ‘Clint” method but I used mineral spirits rather than naptha (‘cause that’s what I had). Didn’t damage the underlying finish at all. I didn’t really bear dowm on the gray Scotch pad when I cleaned the table top as I was afraid I’d go through the finish.
View FMG's profile
FMG
#7 posted 12-16-2011 05:49 AM
Thanks everyone, Clint I got some Naptha and was able to get through a layer but some of the original finish was in bad shape and the previous owner (In-laws) tried to cover it with a healthy coat of wax. Bertha I did end up breaking out a card scraper and went at it. It was my first time using one and I loved it. What a simple and great tool, less mess and no smell either. I sanded down one of the legs and applied some minwax early american and it is just about dead on.
- A1 Jim I’m glad to see your still on here.
Thanks again everyone,
Rick
