Forum topic by Ryan Haasen | posted 12-15-2011 03:08 AM | 1275 views | 0 times favorited | 4 replies | ![]() |
I recently got a grizzly bandsaw. It works great in every way except it has slight blade flutter. I have played with the tension to try and eliminate the flutter, but no success. I then used a pressure gage and discovered a very slight high spot on the upper tire. I assume the high spot is on the tire because if it was the cast-iron wheel, there would be extreme vibration. Is there a way to get rid of this high spot? Advice is appreciated Thanks, Ryan -- Ryan |
