Fixing Screw Holes
Forum topic by CubsFan posted 12-13-2011 05:15 PM 852 views 0 times favorited 6 replies Add to Favorites Watch
View CubsFan's profile
CubsFan
27 posts in 3186 days
12-13-2011 05:15 PM
I’m making a jewelry box for my niece (from Wood Magazine 165), and I’m at the point where I’m putting the hinges on. Anyway, I ordered the hinges that the article recommended. I then pre-drilled the holes, and drove in a #4 steel screw first to clear the way for the brass screw.
Anyway, I’ve now found out that the brass screws are actually #3 screws, so I have a #4 hole for #3 screws. I haven’t been home to see if it’ll still work out for the #3 screw, but I’m assuming that it won’t.
The hole is on a board that’s 1/4” wide curly maple. Any thoughts on what to do? If I get super lucky the #3 screws will fit, but I’ve never been super lucky :)
Thanks!
View ShaneA's profile
ShaneA
7043 posts in 2770 days
#1 posted 12-13-2011 05:22 PM
Buy a 1/8” dowel, drill a 1/8” hole, glue it in, pare it flush and repeat the pilot hole process.
View Lee Barker's profile
Lee Barker
2170 posts in 3022 days
#2 posted 12-13-2011 06:06 PM
I use round toothpicks for this kind of situation. Birch are better than the imported wood. I pay a ridiculously high price for a round container of fancy ones that actually look lathe-turned on one end.
I have also purchased small dowels at craft and hobby stores, plastic bag of ‘em 4 inches long by an eighth.
Ever so handy.
Kindly,
View longgone's profile
longgone
5688 posts in 3480 days
#3 posted 12-13-2011 06:23 PM
I did the same thing with oversized screws. I filled the hole with epoxy and re-drilled with a smaller bit than the first one i used. Worked just great.
117270 posts in 3749 days
#4 posted 12-13-2011 06:40 PM
I agree with Lee but almost any wood glued in place will do the trick.
CubsFan
#5 posted 12-13-2011 09:34 PM
Thanks for all the suggestions! I think I might have gotten lucky. Did a quick test at lunch and it seems like the #3 screws grab and hold just fine in the #4 holes. But I am interested in the toothpick method for future reference. Do you just put ad many toothpicks in there as you can get and fill the hole with glue?
View RZH's profile
RZH
73 posts in 3281 days
#6 posted 12-13-2011 09:48 PM
I use wooden match sticks for bigger holes too…
-- Ron
