Help me choose a miter saw
Forum topic by rpearlberg posted 523 days ago 1946 views 0 times favorited 30 replies Add to Favorites Watch
View rpearlberg's profile
rpearlberg
16 posts in 523 days
523 days ago
I want to buy a miter saw. My first project will be installing crown molding, but otherwise it will be used for general household upgrades and repairs.
I’d like to stay under $300…
Thanks!!!
30 replies so far
View 000's profile
000
3352 posts in 783 days
#1 posted 522 days ago
OMGA MEC 300 ST tapered pins lock the cast iron table, 14” blade so no need for a doofus slider mechanism, and Quiet Quiet Quiet it is probably the best money can buy.
Makita LS1440 Heavy cast iron and accurate
Bosch GCM 12 GDL 305mm slick and snazzy
-- When the moderator chooses sides, his site sucks.
View richgreer's profile
richgreer
4474 posts in 1241 days
#2 posted 521 days ago
At one time, a miter saw was primarily a carpenters saw for cutting framing material and, perhaps, crown molding. Earlier models did not offer the clean, accurate cut woodworkers often need.
That’s changing. There are now miter saws that rival table saws for clean, accurate cuts. That’s still not true in my shop.
With your budget, you can either get a cheap sliding compound miter saw or a more upscale non-sliding miter saw. Unless you have a big need for a saw that can cut a wide board (more than 8”) I would stick with a non-sliding saw.
I’m not going to get into brands because I don’t know enough to make a good recommendation. Mine is a Makita SCMS but I don’t recommend it.
As an FYI – I think miter saws are one of the worst tools in the shop with respect to generating dust. I’ve not seen a dust collection set up that works very well with a miter saw. In general, Festool gets very high marks for dust control and their miter saw (which costs $1,300), when connected to their dust extractor, still only captures 90% of the dust, according to their claim.
rpearlberg
#3 posted 521 days ago
Thanks for the responses. That is one of the things I’m trying to decide…
Get a cheaper saw that has all options (slider/laser, etc) or one for the same price, but a better saw without some of the options…
Right now I’m looking at the DeWalt DS713 10” non-slider, but am open to other options.
I can get this one for about $180 on amazon or $200 at HD.
There is also a Ryobi at HD for $179 that is a slider….
View ShaneA's profile (online now)
ShaneA
3958 posts in 765 days
#4 posted 521 days ago
That 10” dewalt is a nice saw, I have used one few times. Very smooth. The Ryobi, not so much. Blade choice will be a big impact .
rpearlberg
#5 posted 521 days ago
You think that the 10” DeWalt is more than enough saw for doing crown molding and other random household projects?
View Grandpa's profile
Grandpa
2380 posts in 842 days
#6 posted 521 days ago
I have a 9” Rockwell from the ‘70’s and a 12” Bosch slider from the 2000’s. I bought both of them used when they were in like new condition. The Rockwell is as plain as they come. It is as solid as they come. It still makes very clean accurate cuts. I still use it. The Bosch makes more sawdust than a lumber mill. It makes good cuts but weighs a ton when it needs to be moved. I got it for $300 so it is not out of your range. When I bought the Rockwell, I paid $175 (probably more in today’s money than I paid for the Bosch). Not everyone had a powered miter saw in those days. I like both and use them both. Buy a good saw and forget the gimmicks. The blade you install makes the cut. You get what you put on it.
View mikema's profile
mikema
141 posts in 752 days
#7 posted 521 days ago
I have a 10” miter saw, non-slider. Don’t buy one, it is far too limiting. Get at least one with a 12” blade, and get one with a good reputation, like the Dewalt or Bosch. I have gotten to the point where I don’t trust the angle scales on mine, and check it every few cuts. In fact I don’t even use it where precision is needed, I go to the table saw. For me, the next miter saw I get will be a high-end 12” slider. With your budget, look at criagslist, saws like this often show up within the budget you have… Just don’t let them sit too long as they will get snapped up quick.
Whatever saw you get, toss the blade it comes with and put a good one on it.
-- Mike ---- Visit my woodworking blog: http://sawdustnewbie.com
richgreer
#8 posted 521 days ago
IMO – The laser is of very limited value. Sometimes they are built into the package and, in theory, cost very little extra. However, if you could get a slightly better saw for the same money by giving up the laser I would do that.
In the interest of full disclosure, I bought a laser for my miter saw and installed it. In retrospect, I regret spending the money.
View Bertha's profile
Bertha
13111 posts in 859 days
#9 posted 521 days ago
I see DeWalts all over the WV craigslist. $300 would buy your two of them. Good luck!
View renners's profile
renners
1879 posts in 1135 days
#10 posted 521 days ago
Don’t buy the Ryobi unless you want to chuck it away when it breaks. You can’t get spare parts for love nor money.
-- Do or do not, there is no try
View Sawkerf's profile
Sawkerf
1776 posts in 1235 days
#11 posted 521 days ago
What size crown are you installing? Is it stain or paint grade?
$300 isn’t going to get you much of a miter saw unless you can get lucky and score a used one that hasn’t been used to death.
A simple miter saw (non-sliding) will work fine for crown if it can be cut standing straight up against the fence. The max size of the crown depends on the clearance between the table and the saw blade.
If you’re planning to paint your crown you don’t need a top of the line miter saw. Less than perfect joints can be filled and sanded. If you’re going stained crown, don’t go cheap on your saw.
The laser can be handy – if you take the time to get it dialed in just right. I have mine set to cut on the left side of the laser beam and it can make things easier. Contrary to popular opinion, Ryobi makes pretty decent tools. I use Ryobi for my on site work and can do almost anything I can do in the shop.
View Abe Low's profile
Abe Low
111 posts in 2012 days
#12 posted 521 days ago
Look into a used radial arm saw. You can get a great one for your budget. Don’‘t skimp on the blade.
The only reason for the miter saw is if you need to transport it to job sites. A 12” slider takes up more floor space than a radial arm saw. Do your own research and follow your results.
-- Abe Low, Fine furniture, Sacramento, CA
View Bill White's profile
Bill White
2601 posts in 2127 days
#13 posted 521 days ago
I have a DeWalt 10” non-slider with a Freud 80 tooth blade. Smooth, accurate, and relatively inexpensive. Used it to trim our new home. I used 7 1/4” crown which was too wide for the saw. Another fellow installed the crown with 12” slider. Other than the really wide crown, the DeWalt has been a great buy.
Whatever ya get, put a good blade on it.
Bill
-- bill@magraphics.us
rpearlberg
#14 posted 521 days ago
Thanks Bill. For now I plan on using basic 3 5/8” crown so the 10” non-slider should be plenty….still can’t make a decision!!
View agallant's profile
agallant
366 posts in 1053 days
#15 posted 521 days ago
I would stay away from Rayobi. I have the ‘nice’ sliding CMS from them, it is OK but my biggest complaint is that the degree markings are not accurate, 45 is more like 42….
showing 1 through 15 of 30 replies
