Norton 3x vs. 'Premium' Sandpaper
Forum topic by gfadvm posted 12-13-2011 01:57 AM 5172 views 1 time favorited 11 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2657 days
12-13-2011 01:57 AM
I went to get more sanding sheets and found no Norton 3x. Instead they had Norton ‘premium’. Is this 3x with a new name? I’m pretty much hooked on the 3x and hate to change.
11 replies so far
View rance's profile
rance
4255 posts in 3128 days
#1 posted 12-13-2011 02:09 AM
I just switched to Abranet for my ROS. I doubt I’ll go back to Norton for that. I sure wish I could find some 8” or 10” disks with velcro though. Sorry I can’t help you on the Premium.
gfadvm
#2 posted 12-13-2011 03:14 AM
cr1, ????
View Woodwrecker's profile
Woodwrecker
4137 posts in 3543 days
#3 posted 12-13-2011 07:31 AM
I’ve had good luck with this place doc.
http://www.industrialabrasives.com/
It doesn’t cost an arm & a leg, and wears like iron.
Good luck.
-- Eric, central Florida / Utor praemia operibus duris
gfadvm
#4 posted 12-14-2011 04:07 AM
Woodwrecker, Does it cut/sand as quickly as the Norton 3x?
gfadvm
#5 posted 12-15-2011 04:30 AM
UPDATE: Went to Woodcraft today and they have Norton 3x so maybe the Norton ‘premium’ is their big box label ? Confusing huh?
View Don Carrier's profile
Don Carrier
114 posts in 2344 days
#6 posted 12-15-2011 05:11 AM
I’m a big fan of Norton 3x. I don’t think premium is the same.
I’ve found nothing better at all and I’ve tried a lot of different papers. It’s stocked at woodcraft, but like most everything they sell it’s expensive. Peechtree directly or via Amazon is the best deal I’ve found. About 31 bucks for 50 discs.
-- Don
gfadvm
#7 posted 12-15-2011 05:28 AM
don, I’ve been a big fan of 3x but I bought a ‘sampler’ of Abranet discs today (35 discs for $35). The grits are 80 to 600. I spent the afternoon sanding some Jatoba (really hard) and I think I may be an abranet convert! Thet sand FAST like 3x but they don’t pick up any debris (never needed my crepe cleaner). My sander is connected to my dust collector and the discs stayed really clean and show NO signs of wear yet. They are definately worth a try. Thank Rance for turning me on to these. I’m going to see if someone has already reviewed Abranet discs.
rance
#8 posted 12-16-2011 08:34 PM
A WC employee friend of mine uses LOTS of Abranet and gets his online. I’ll try to find out where. WC only sells the small packs. You should check out Klingspor.com also. They have good paper too. As good as 3x IMO.
View pintodeluxe's profile
pintodeluxe
5623 posts in 2781 days
#9 posted 12-16-2011 08:38 PM
Klingspor VD900 series recently rated equal to the Norton 3x, and at a better price. The article was in Fine woodworking magazine.
You can buy them at Woodworkingshop.com
gfadvm
#10 posted 12-17-2011 03:44 AM
Thanks guys, I’m an Abranet convert for sure now that I’ve been using it for the past 2 days. I no longer hate sanding. I hate to admit it but this stuff is much better than Norton 3x.
View CedarSlayer's profile
CedarSlayer
7 posts in 3309 days
#11 posted 12-22-2012 08:45 PM
To answer the original post,
I purchased a deeply discounted bundle of Norton 3X from Peachtree http://www.ptreeusa.com/index.htm. When it came in the boxes of 20 sheets said PREMIUM, but the sheets say 3x. It could be that the 5x label confuses or the relative term of 3x confuses over the long term so they are rebranding.
Continuing the thread,
I do like Supergrit. I buy most of my ceramic belts from them. http://www.supergrit.com/products/products_belts-ceramic.asp
Ceramic belts are tough. If you want to make a sanding tool such as a block that will hold up, use a section cut from a ceramic belt.
When using Norton 3X on wood, I find that I can clap the sandpaper with a block of wood or against wood, like you would a chalkboard eraser. This does a great job of cleaning the Norton 3x. It also works well on the White Mirka Abraisive PSA rolls.
-- http://toolmakingart.com
