Titebond White Trim And Cabinet Glue
Forum topic by gfadvm posted 12-13-2011 01:53 AM 1392 views 0 times favorited 11 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2688 days
12-13-2011 01:53 AM
Topic tags/keywords: glue
Does anyone else use this? I like it for small projects (boxes) as it doesn’t run, will fill a gap, and dries clear. Strength is comparable to TB 2 and 3 according to TB website. Anyone see a problem with this stuff?
11 replies so far
View rance's profile
rance
4258 posts in 3158 days
#1 posted 12-13-2011 02:07 AM
You’re ahead of me on this. I’ll sit back and learn from you guys.
View Loren's profile
10390 posts in 3646 days
#2 posted 12-13-2011 02:36 AM
I prefer white glue for cabinet and furniture work, generally. I prefer
the longer set time and it does seem to dry brittler and creep less
than yellow glue in lamination work. I buy Elmer’s or whatever.
13603 posts in 3339 days
#3 posted 12-13-2011 02:53 AM
o use white glue for dowels
it is thinner and doesn’t plug
and split the hole
from hydraulic pressure
use scored dowels
to let it out
and spread it evenly
rance
#4 posted 12-13-2011 02:53 AM
Dooooh, it just occurred to me what glue you were talking about. I use their “Molding & Trim” glue. Is that what you are referring to?
I use it in my box class because it dries faster. We glue the box up and let it sit while we work on the lids. Its only a 3 hour class, we gotta hurry all we can. :) It is supposedly engineered for end-grain joints(or miters). I am perfectly happy with it.
gfadvm
#5 posted 12-13-2011 03:18 AM
That’s it Rance. David and Loren must use a different type of white glue as this stuff is very thick and sets up QUICK. Still looking for some downside or contraindications guys. Its the stuff Rance pictured. I had the name wrong, sorry.
View Brad_Nailor's profile
Brad_Nailor
2539 posts in 3955 days
#6 posted 12-13-2011 03:44 AM
Ill have to get some and try it on end grain stuff..
117091 posts in 3575 days
#7 posted 12-13-2011 04:46 AM
It’s a new one on me too. Sounds interesting.
View Jim Jakosh's profile
Jim Jakosh
20482 posts in 3103 days
#8 posted 12-13-2011 05:24 AM
I’ve seen the label now that you posted it but never read up on it. I think I’ll stick ( no pun intended) with TB III which is all I use now….............Jim
View Mathew Nedeljko's profile
Mathew Nedeljko
715 posts in 3827 days
#9 posted 12-13-2011 05:37 AM
Hi, I am currently using this glue to assemble the wood mosaic pattern on another lazy susan project I am working on. It has such high initial tack that you only need to press it together for a few seconds and it stays put. It dries clear and very quick. It is also thick so it does not run at all. In fact when you squeeze it out of the bottle it just kind of sits there in a little pile. I have no reservation about using it for specialty applications like this, but I really would not use it where any open time was required during assembly.
-- Aim high. Ride easy. Trust God. Neale Donald Walsch
View Jim Finn's profile
Jim Finn
2656 posts in 2920 days
#10 posted 12-13-2011 05:55 AM
I use Elmers white glue on all of my inlay work and cedar boxes. Dries clear, and quickly.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Woodwrecker's profile
Woodwrecker
4148 posts in 3573 days
#11 posted 12-13-2011 07:34 AM
Got to try some of that.
Thanks for the tip.
-- Eric, central Florida / Utor praemia operibus duris
