Woodhaven Planing Sled
Forum topic by Don Carrier posted 12-12-2011 03:48 PM 6113 views 0 times favorited 4 replies Add to Favorites Watch
View Don Carrier's profile
Don Carrier
114 posts in 2550 days
12-12-2011 03:48 PM
Topic tags/keywords: jig question
Anyone recommend/not recommend this tool? I am in desperate need of a way to mill endgrain. I’ve look at some of the homemade projects, but I am need something pretty quick and I was considering this jig.
Link
-- Don
View agallant's profile
agallant
551 posts in 3060 days
#1 posted 12-12-2011 07:38 PM
This just looks like a bad idea. One slip and you have put a big dent in your wood.
View jmos's profile
jmos
891 posts in 2543 days
#2 posted 12-12-2011 07:47 PM
A month or two back FWW did a cover story on some actor/woodworker that uses a shop made sled similar to that to flatten large slabs he uses for tables. Seems to work pretty well. I’ve also seen something similar used to flatten a workbench (Wood Whisperer I believe), also a home made jig.
Like Rick said, you could really make something similar yourself, but the jig you link to looks pretty solid if you wanted to buy one that one.
Have you tried just using a plane? A low angle jack plane should work pretty well and would be more versatile.
-- John
View Viking's profile
Viking
880 posts in 3369 days
#3 posted 12-12-2011 07:57 PM
Don;
As the other Rick above notes, don’t waste your money on this when you can build one yourself. Ther are several good one on this site if you search for “router planer”. Here are a couple but there are many to look at.
http://lumberjocks.com/TZH/blog/18754
http://lumberjocks.com/projects/10177
http://lumberjocks.com/projects/40923
Good luck!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
View Dragonsrite's profile
Dragonsrite
136 posts in 3571 days
#4 posted 12-12-2011 08:01 PM
Before I picked up a thickness planer I used this method to turn firewood into usable boards. That’s right… 16” logs, split with an axe, flattened and brought to thickness with a router sled. Here’s the result…
http://lumberjocks.com/projects/13862
As Rick mentioned above … an hour (or less) to make your own.
-- Dragonsrite, Minnesota
