Cutting Board Question #2
Forum topic by MashMaster posted 12-12-2011 05:01 AM 1998 views 0 times favorited 11 replies Add to Favorites Watch
View MashMaster's profile
MashMaster
134 posts in 2900 days
12-12-2011 05:01 AM
I have been doing a few cutting boards and noticed that the mineral oil (usp) turns the work darker than I thought it would. Maple comes out like a light caramel color. I saw the boards to 400 grit first. The other boards I see here seem to be a brighter color than mine.
-- - Dave ; Austin, TX
11 replies so far
View Betsy's profile
Betsy
3392 posts in 4135 days
#1 posted 12-12-2011 05:05 AM
I don’t like mineral oil for just that reason, the boards always seem darker. I’ll be interested to see if anyone has an explanation for that. Personally I use walnut oil and have always enjoyed the look.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
MashMaster
#2 posted 12-12-2011 05:06 AM
I’d use that but my wife is allergic to nuts.
View Jonathan's profile
Jonathan
2609 posts in 3290 days
#3 posted 12-12-2011 06:00 AM
Make sure to also stay away from tung oil then too.
The thing I’ve noticed when using Salad Bowl Finish for a board is that with time, the SBF wears off. You then have to decide if you want to lightly sand it, then re-apply more SBF and wait several days for it to cure before using the board again, or simply begin using mineral oil to reseal the board. With this approach though, the board will darken where it’s used the most, as that’s where the mineral oil will be most readily absorbed.
You could use something that is more beeswax or carnauba wax-based and that will likely help with the color issue, but will not provide as much “deep” protection for the board as a saturated/near-saturated mineral oil finish.
I don’t have any explanation on the color difference when using mineral oil, but am curious to hear why that happens.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View ShaneA's profile
ShaneA
7064 posts in 2838 days
#4 posted 12-12-2011 06:45 AM
The darker color should be the same look as if the board was wet with water or any other clear liquid. The oil penetrates for protection, but leaves the board with a “wet” look. If it is an end grain board, even more oil will penetrate, giving an even darker color than face grain boards. I guess the color change is subjective, I tend to like it better with oil, it seems richer/deeper. I am unaware of a way around it, buy there may be one.
View Tootles's profile
Tootles
808 posts in 2741 days
#5 posted 12-12-2011 12:48 PM
Degoose posted a while ago that he uses grape seed oil. If he doesn’t reply to this blog, perhaps send him a pm to ask what effect that has on the wood.
-- I may have lost my marbles, but I still have my love of woodworking
View WillieIV's profile
WillieIV
11 posts in 2597 days
#6 posted 12-12-2011 05:45 PM
Sure wish the “shine” would stay with a board that only has mineral oil applied. They look so nice once finished and before you actually use them!
Jonathan
#7 posted 12-12-2011 08:35 PM
@WillieIV, a topcoat of beeswax (or a combo topcoat with beeswax in it) will help maintain the shine, and help repel water too. I know you said “only has mineral oil applied,” but I thought I’d throw it out there.
View dustbunny's profile
dustbunny
1149 posts in 3535 days
#8 posted 12-13-2011 12:50 AM
I use Howards Butcher Block Conditioner, once it dries it has a bit of shine to it. It is mineral oil and natural waxes mixed together.
Another tip for shine….
Sand the board to 200 grit, spritz the board with water to raise the grain, then sand again to 220.
When you apply finish to grain that is unraised, the grain raises with the finish and gives a dull appearance.
Try it, I think you will see a difference.
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
Jonathan
#9 posted 12-13-2011 03:14 AM
I have also used the butcher block conditioner that Lisa mentioned for recoating. Seems to work fairly well. It’s more mineral oil than beeswax, as it’s a thick liquid at room temperature.
View Jim Jakosh's profile
Jim Jakosh
21973 posts in 3345 days
#10 posted 12-13-2011 05:41 AM
I use Behandla from Ikea for anything that touches food. It is clear when applied to maple. It takes 24 hours before you can recoat. Mineral oil will be faster!
MashMaster
#11 posted 12-13-2011 06:03 AM
warning “Behandla” has tung oil in it, so nut allergic people may react
