| Forum topic by Weatherman | posted 526 days ago | 848 views | 1 time favorited | 8 replies | ![]() |
526 days ago |
Topic tags/keywords: drum sander question shaft rod Hi guys. I’ve been lurking around here for months now and finally decided to post. I’ve seen some awesome projects here by everyone and learned a lot. I’m getting ready to batch out some cutting boards and I’ve been wanting to build a drum sander to help the process. The last cutting board I built took forever to sand the end grain with the RO. I’ve searched through and seen all the designs posted and they’re great. My question deals directly with the shaft for the drum. Where did you guys buys yours? I’ve seen some people say home depot or lowes, but I can’t find anything thick enough there without going to the galvanized pipe. I know I can order it from a few places online, but I was just curious as to if some of you guys got yours locally. Thanks! -- Brian |
8 replies so far
#1 posted 526 days ago |
Local welding shop will have cold rolled shafting. Online, McMastr Carr is my favorite “go to” source for everything mechanical. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#2 posted 526 days ago |
Well, I dunno where you are located, but metal dealers, especially That said, building machines is not for the faint of hard and the investment Also, I see used drum sanders on the market all the time, and believe |
#3 posted 526 days ago |
Two suggestions; go to www.woodgears.ca for tons of information including pdf of a drumsander build, and go to www.vxb.com for bearings and shafts—cheap, high quality, good service, and huge selection. If they don’t have it, it doesn’t exist. And welcome to LJ. Steve PS You know why God invented weathermen don’t you? To make economists look good. Just kidding. -- Steve in KY. 44 years so far with my lovely bride. Think I'll keep her. |
#4 posted 525 days ago |
One option may be tread-all. Recently shop-notes Vol.20 Issue 119 made a shaping center using 5/8” threaded rod It fit directly into a 5/8” pillow block bearing and they used jam nuts against the grinding wheels to hold them in place.You may want to step up to 3/4” for more rigidness. I don’t know that thread-all would be the best but $10 is a lot better than $40 when your on a budget. |
#5 posted 524 days ago |
Never heard it called thread-all, but if you mean all-thread rod, that is a poor choice for a shaft. Not straight, low grade steel, full of stress fractures from the threading process. If I had no other choice I might use it but I’d go with 1” diameter. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#6 posted 524 days ago |
I got it on EEEEEEEEEEE BAAAAAYYYYYYYYAny metal’s dealer on line will sell you bar stock and some will have ground shafting. Most mill spec bar stock is good enough and pillow block bearings usually let you drive a pair of set screws hard into the bar. ”all-thread rod, that is a poor choice for a shaft. Not straight, low grade steel, full of stress fractures from the threading process. If I had no other choice I might use it but I’d go with 1” diameter.” All-thread has got no roundness specification and no consistent diameter either. Put a shaper cutter on an All-thread shaft and one is guaranteed to only have one side of the cutter doing any work. Plus the wear – - there is less metal to metal contact and the thread crests will wear like a who dun it. -- When the moderator chooses sides, his site sucks. |
#7 posted 524 days ago |
I got my some of my shafts from a bearing and drive store, they had to order it in on a stock order, but it was -- As ever, Gus-the 74 yr young apprentice carpenter |
#8 posted 524 days ago |
Thanks for the suggestions guys. I called around a few places here and eventually ordered it off amazon. The prices were about the same but the shipping was much cheaper with the prime membership. @Loren – This wouldn’t be for just these cutting boards, but for future projects as well. All tools are an investment, regardless of if they’re built or bought. -- Brian |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
