Variable speed conversion kit
Forum topic by Pitdull posted 12-12-2011 12:22 AM 1626 views 0 times favorited 1 reply Add to Favorites Watch
View Pitdull's profile
Pitdull
17 posts in 2283 days
12-12-2011 12:22 AM
Topic tags/keywords: question
Hi every one. has any one used the variable speed conversion kit ?
From penn state Industries .
If so did it work good ?
1 reply so far
View brtech's profile
brtech
1017 posts in 2826 days
#1 posted 12-12-2011 04:50 PM
If you want something for a router, check this out:
http://www.vhipe.com/product-private/SuperPID.htm
This turns nearly any router into a closed loop variable speed router where it’s controlled speed – you get a constant speed no matter what the router is doing, up to the limit of the router’s power.
This is DIY territory, because you have to modify the router to add a sensor to the shaft and disable any speed control it has.
The DIY CNC crowd loves this product.
