Rookie looking to start first project
Forum topic by Iggles88 posted 12-11-2011 09:00 AM 2001 views 0 times favorited 21 replies Add to Favorites Watch
View Iggles88's profile
Iggles88
247 posts in 2596 days
12-11-2011 09:00 AM
Hey all, I’m new to woodworking just getting the shop together, I’m pretty good with my hands but am new to the woodworking scene, so far I have a table saw, jointer, jigsaw, ro sander, finishing sander, fixed base router, plunge router, brad and finishing nailer w/ compressor, clamps, and all the necessary hand tools…..I’m looking for a simple project idea to help me gain experience with various techniques while gaining some confidence…....any help would be greatly appreciated…...I’m also looking to for suggestions on the next tool I should buy. People always ask me what I want to build so I guess I’ll answer that now, im interested in building simple furniture at first until I gain the skills to build more intricate furniture for my house, thanks for the advice in advance
21 replies so far
View Sawdust4Blood's profile
Sawdust4Blood
408 posts in 3257 days
#1 posted 12-11-2011 09:14 AM
Wood magazine and popular woodworking both regularly do basic projects designed to build skills. Try beginning there. Sounds like you have a pretty functional sets of tools to begin with. Start doing things and see where it goes from there. There’s always another tool to have so I would recommend adding them as you need them for projects.
-- Greg, Severn MD
View Loren's profile
10477 posts in 3883 days
#2 posted 12-11-2011 09:24 AM
Get a planer.
Build a work bench.
How are you going to make the mortises?
Chisels work and there are different types. I have a lot of chisels
and can’t seem to stop acquiring them. Mortising machines work too,
and there are two major types: hollow chisel and slot mortiser –
one of which you can build yourself. Then you get into loose tenon
vs. mortise and tenon. Tenoning can be a pain but it is an essential
legacy skill you can avoid if you like by using biscuits or loose tenons
or whatever. I recommend learning how to do it before you become
addicted to “cheating” on tenoning.
A fine bandsaw can help with tenons and all sorts of other things.
View Eagle1's profile
Eagle1
2066 posts in 3300 days
#3 posted 12-11-2011 04:14 PM
I have to agree with sawdust4blood. Most of the woodworking books have projects for different levels of experince. Personally I would start with making a box. 1 you can uswe it for things in the shop that you need to put something in. Make it with 45 angle’s that is a good way to learn. Box’s with 45’s can be a pain, alot of people will tell you that. Then I would just work up from there.
As far as the next piece of equipment I would get a bandsaw. There are a lot of things to get you started to learn after that.
By the way welcome to LumberJocks.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View Lumber2Sawdust's profile
Lumber2Sawdust
139 posts in 3100 days
#4 posted 12-11-2011 05:15 PM
I have to agree with Loren’s recommendation of building a workbench.
I used various items as a workbench in the past, from sawhorses on a gravel floor, to a particle board shelf in the corner of a garage. Building the workbench was a great project. The bonus is that you have a great place to work for future projects. I was reminded of that fact yesterday as I work on some gifts for Christmas and was able to clamp a piece in the vice on the bench. I’m still learning all of the ways the workbench can make life easier, but it has made my woodworking much more enjoyable.
The bench I build was a design featured on Fine Woodworking’s Tools and Shops issue in about 2004. Find a design that works for your needs, budget and skills, and start making sawdust.
Good luck
View jumbojack's profile
jumbojack
1685 posts in 2859 days
#5 posted 12-11-2011 05:50 PM
Welcome to Lumberjocks!
I echo the idea to start with a few boxes. Most projects revolve around the box. The knowledge you gain from such a ‘simple’ undertaking will open your eyes to what you don’t know.
Learn to use the jointer, it is not difficult but there is a learning curve.
I also think the next tool you ‘need’ is a planer. There is nothing harder than trying to build something that is ‘square’ with material that is not. Building on that idea, you absolutely need something to check for square. It can be as simple as a stick to check diagonals, but square is essential.
You are going to make mistakes and covering them or fixing them is part of the mystique we all enjoy. Do not be discouraged by them. Woodworking mirrors life, you deal with the hand you dealt.
Mir
Jack
View ShaneA's profile (online now)
ShaneA
7063 posts in 2833 days
#6 posted 12-11-2011 06:18 PM
Welcome, I like the suggestions given above. A workbench or other shop accessories where you can hone your skills and practice would be a good start. Less expensive materials used on these will also be good if mistskes are made. Good luck.
View RGtools's profile
RGtools
3372 posts in 2890 days
#7 posted 12-11-2011 06:22 PM
If you don’t already own one a solid combination square (Starrett makes the best) is an important tool for both hand and machine work.
As far as a first project pick something that needs to be functional but does not need to be perfect (a small step stool would accomplish this). If it fills a need in your shop or your home, you will look at it everyday and learn from it. Years from now you will look at t and see just how far you have come. A workbench is good too, but if you are going the power route it can be avoided until you can dream up the bench you want. Build a strong set of sawhorses instead.
-- Make furniture that lasts as long as the tree - Ryan
Iggles88
#8 posted 12-11-2011 06:29 PM
Thanks everyone for the advice. Ive received the suggestion of the workbench a bunch of times and while I’d love to build one I’d really like to wait until I can build the workbench that I’m envisioning in my head like RG said. I have a combination square, I have enough tools to check for square. I should mention I’m not brand new to woodworking, I’ve spent plenty of time in woodworking shops when I was younger however I never got my hands dirty so now I’m giving it a go because i was always fascinated with some of the projects that would come out of my grandfathers shop, I’m excited to get into a project I just didn’t want to rush into a project and fail, I wanted to find a good project that I could successfully finish to build some confidence. Not a final decision but I think I’m going to build a wall shelf and towel rack. From page 80 of 2010 best ever woodworking projects and shop tips. My thoughts on my next tool were either a track saw, planer, or router table. Thanks again for everyone’s suggestions and advice.
13641 posts in 3576 days
#9 posted 12-11-2011 06:41 PM
the journey
of a thousand projects
begins with the first one
have a great trip
and welcome to LJ’s
View BigYin's profile
BigYin
421 posts in 2651 days
#10 posted 12-11-2011 06:51 PM
Make a traditional tool box
http://www.download-it.org/free_files/Pages%20from%20Chapter%204%20Making%20a%20Carpenters%20Tool%20Box-5e9267f4defbbe22287ea6d2771fef32.pdf
(Copy and paste all of it)
-- ... Never Apologise For Being Right ...
Smitty_Cabinetshop
15799 posts in 2853 days
#11 posted 12-11-2011 09:26 PM
Or a six-board chest of a size that’s most useful to you. Even one that’s sized to be a sawhorse for the shop…
View Don W's profile
Don W
19040 posts in 2803 days
#12 posted 12-12-2011 12:57 AM
think of something you need or want and build it. Look through project here as well. Recommendations for the next tool is going to be difficult because we all build different. My suggestion is start building stuff. As you find you want or need tools, buy or make them.
You will find a lot of use here find and restore older tools. That’s an option but not for everybody. I’d recommend starting with hand tools, but then, I didn’t.
Welcome to LJ’s. Have some fun.
View Betsy's profile
Betsy
3392 posts in 4131 days
#13 posted 12-12-2011 01:05 AM
Just try making something square – once you get that down everything else is easy!
Welcome to LJs. It looks as if you’ve got a great set of tools started. The suggestions above are good ones. I got hooked when I made a few simple toys for my nephews it was all downhill from there.
You might want to look at the books with “weekend” projects. They are generally very basic yet give you the chance to try new things. I wouldn’t start with anything big. It’s expensive and you may get discouraged. Start small and go from there. Also I’d suggest looking at some classes at your local Woodcraft or Rocklers. There are also several woodworking schools that have weekend classes.
Good luck and welcome to the fold of sawdust makers. :-)
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
Iggles88
#14 posted 12-12-2011 03:40 AM
Betsy hit the nail right on the head, I don’t want to get discouraged by failing at my first project that it what this is all about. I also was intrigued by the thought of building things for my two baby sisters along with an on the way Bruce or nephew, I was looking at plans for a simple rocking horse but even that I’m thinking might be too much for me right now. All of the suggestions have been taken into account and they’re all good ones. I definitely want to start with building something square, I built a very simple bookcase once before for work but I had problems getting everything square because I skipped steps that I wouldn’t skip now, I finished the bookcase but I wasn’t exactly proud of it (although the person it was built for loved it, or so they say.) I really appreciate all the help and love this website, it’s amazing how many people have responded and how many people want to lend some advice. I will definitely remember this when I’m a seasoned vet! Thanks again
View gfadvm's profile
gfadvm
14940 posts in 2925 days
#15 posted 12-12-2011 05:48 AM
I would recommend you build some stuff for your shop. Boxes with mitered corners, box joint corners, and other types of joinery are good technique builders. I would also strongly recommend you build a good ‘Super Sled’ for your table saw. It will be invaluable to you. Shop storage with drawers is another skill builder (use different joinery methods for the drawers). These should get you off to a good start. And keep you busy for a while! A planer would be my recommendation for your next tool followed by a bandsaw.
