Stanley No. 5 Iron Question
« back to Hand Tools forum
Forum topic by econsigny posted 12-11-2011 05:32 AM 1373 views 0 times favorited 5 replies Add to Favorites Watch
View econsigny's profile
econsigny
9 posts in 2327 days
12-11-2011 05:32 AM
So I snagged a No. 5 off of ebay and low and behold the iron looked good, but upon sharpening it I notice that about one side of the blade, about a 3/8” section from one side, is not even with the rest of the blade. It isn’t chipped, and there is no evidence that the iron was dropped onto a hard surface on the corner of the blade.
Conceivably, if I sharpen it for long enough the blade should even up right? Again, no chips, and no signs of destruction. Yet I would not go so far as to say one side it beveled because it does not look intentional.
Thoughts?
5 replies so far
View MrDan's profile
MrDan
205 posts in 3250 days
#1 posted 12-11-2011 05:44 AM
Having a hard time picturing that…can you post some photos?
View Loren's profile
10244 posts in 3610 days
#2 posted 12-11-2011 09:29 AM
Grind it square on a white grinding wheel, and dip in water to keep
it cool so you don’t burn it. Then grind it hollow to make the hollow
converge with the straight edge. Dip in water plenty lest you burn the
steel. Then you have a ground square iron. Then sharpen the bevel
on your stones to whatever high grit you can work to.
View Don W's profile
Don W
18684 posts in 2530 days
#3 posted 12-12-2011 12:36 AM
As with MrDan, I’m having a hard time understanding exactly what you mean. I wouldn’t grind it down 3/8” from a side.
View blackcherry's profile
blackcherry
3337 posts in 3785 days
#4 posted 12-12-2011 02:48 AM
Sounds like the previous sharpening when out of square, as stated by Loren a new hollow grinding is due to straighten thing out again. It happen to the best of us no big deal the blade should work great once it all squared and sharpen…BC
View Rev_John's profile
Rev_John
93 posts in 3851 days
#5 posted 12-14-2011 04:25 AM
Grind it square and sharpen, shouldn’t be a problem after that.
-- John from Jackson, Michigan
