| Forum topic by Bobby Shay | posted 527 days ago | 696 views | 0 times favorited | 10 replies | ![]() |
527 days ago |
I have heard that I should be careful about using lubricants on my radial arm saw because it causes saw dust build up. What lubricant should be used to prevent this from happening ? Thanks for your advice. -- Bobby |
10 replies so far
#1 posted 527 days ago |
I suggest wax. The easiest place to find is the wax that they sell for bicycle chains. -- Woodworking shouldn't cost a fortune: http://lowbudgetwoodworker.blogspot.com/ |
#2 posted 527 days ago |
Dricote in the spray can works pretty well without much of a buildup. You might try Johnson’s floor wax or good ol bees wax. I use bees wax for quite a few things now that I raise bees. But even before, I used it when I could get my hands on it. -- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch) |
#3 posted 526 days ago |
Graphite works well. Most people make the mistake thinking by lubricating they are doing a good thing. If the wrong lubrication is used it is actually causing more problems. An example is patio doors, I repair many that people complain no longer slide freely, they tell me they have used WD40 faithfully. WD40 collects the house dust which in turn causes the plastic rollers to fail.(I think WD 40 is an abbreviatoin for good lubricant “Watered Down 40 times”) the same goes for your radial arm saw. Wipe the track clean often and do not use anything that will cause the very fine saw dust to stick, blow the rollers with an blast of air. -- "My mission in life - make everyone smile !" |
#4 posted 525 days ago |
I used to be in the camp that eschewed any wet lubes because of the dust. Wax was such an under-performing product to use as a lube that I just couldn’t stand it. Greases ended up balling up the dust, and light lubes ended up being where I settles for most things. Let me repeat that: WD-40 IS NOT A LUBE
#5 posted 525 days ago |
I use wd-40 to REmove tar from my car. I use dry lube on my tools. -- Don't rollerskate in a buffalo herd |
#6 posted 525 days ago |
When I worked as an Ironworker we installed roll-up doors. We used exclusively (silicone spray) because it didn’t collect and build up dust. But you might contact the manufactures to find out for sure, many brass products are impregnated with dry lubricants (graphite, etc). requiring no lubrication for its whole life, if thats proves to be true do not lubricate but give it an air bath on occation. (blow of gear assembly with compressed air). -- another tip from cooperedpatterns |
#7 posted 525 days ago |
#8 posted 525 days ago |
What part of the RAS are you lubing- the post? I have a mill in the barn with a vertical post similar to my RAS and I use chain lube in it. I have some silicone spray lube that I use for the ways on my Ryobi table saw and it works good. At first that saw used to stick so you could not run it all the way down. I took it apart twice and cleaned the ways and lubed them with the silicone spay and now I just vacuum all the dust away and spray the ways and crank them up and down while doing it and it works good for at least a year. By the way, WD 40 stands for Water Displacement! If you have wet misfiring plug wires and dist cap. spray them with WD -40 and it will displace the water that caused shunting /shorting! -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! |
#9 posted 525 days ago |
Except for the table top I’d use graphite. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#10 posted 524 days ago |
Cheaper is to toss a cup of diesel or kerosene on the wires. But truth be told no car should ever get that bad. I remember popping the hood of cars that didn’t want to start in the night time, back in the day when dinosaurs roamed the earth. The cracked and corroded wires would send out so much loose voltage all over the place it was like a high tech light show. Modern polymers are better then they used to be too. -- When the moderator chooses sides, his site sucks. |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1530 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6156 |
