C-clamps with large grips
« back to Hand Tools forum
Forum topic by Betsy posted 12-10-2011 06:28 AM 4449 views 1 time favorited 11 replies Add to Favorites Watch
View Betsy's profile
Betsy
3391 posts in 3889 days
12-10-2011 06:28 AM
Topic tags/keywords: clamps
Okay I can honestly say I’ve looked over a lot of the internet, can’t say I’ve searched it all because that would be impossible. I’m hoping one of you may have an idea where I can find clamps such as the two pictured here.
The grips on these are perfect for me, but I can’t find them. The two I have came with some tool kit, but that kit is long gone.
There is a number on the side that I’ve looked up 1430-3” Adjustable is all that’s one the clamp to identify it.
Any help would be appreciated.
Thanks
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
11 replies so far
View John in SD's profile
John in SD
140 posts in 3806 days
#1 posted 12-10-2011 07:19 AM
Routerforums.com were selling them some time ago, Betsy….but why dont you fashion some on your lathe !
-- Life used to be soooo much simpler!!!!
View DocBailey's profile
DocBailey
584 posts in 2353 days
#2 posted 12-10-2011 07:20 AM
Betsy
#3 posted 12-10-2011 07:38 AM
Thanks for the links. John, while I still do have a mini lathe, with my physical issues it’s not a safe tool for me any longer. Nice idea though. :-) I’ll check out these links and see what I can find.
Thanks
Betsy
#4 posted 12-10-2011 10:28 PM
Doc – those are the exact ones. Thanks for the link. I’m going to be buying several.
Rick Dennington
5851 posts in 3187 days
#5 posted 12-11-2011 01:45 AM
Betsy,
Here’s a suggestion for you….before paying that high price for the clamps (by the way I have 4 also just like that…lol) take the size you like, remove the cross-piece in the handle for tightening it up, take a dowel the length you want, drill a hole down the center to fit the threaded rod (determine the depth you’ll need), epoxy it in, then take a rubber tip, like on a cane, or a pair of crutches, and epoxy it on….you’re good to go, and lot less expensive….I’ve made a 1/2 dozen like that, and they work good…...just a suggestion to save you $$$$$$.......
Betsy
#6 posted 12-11-2011 04:50 AM
What a great idea Rick. I’ll give it a go.
View gfadvm's profile
gfadvm
14940 posts in 2683 days
#7 posted 12-11-2011 05:40 AM
I saw some where someone had pinned a golf ball for a handle on this site. I would think any rubber ball should work depending on the size you like.
Rick Dennington
#8 posted 12-11-2011 09:43 PM
Betsy,
If you try it, and you like it, and it works for you, be sure and post some pics so we can see the finished items…..I’ve made mine like I described to you about 7-8 years ago, and they are still holding…... here’s a couple of pics of the ones I made..might give you an idea or two…..lol
Betsy
#9 posted 12-12-2011 12:54 AM
Rick – thanks for the pics. I’ve got some dowel rod that I’m going to try this with. I’ll post some pics when I get them done. I knew my fellow LJ’s would come through with some ideas. It’s the little things like this that will keep me in the shop longer. So muchos gracias!
Betsy
#10 posted 12-19-2011 02:27 AM
Just an update – I took Rick’s advice and tried the dowel rod and chair leg cover. I think this is definitely going to work for me.
thanks for all the help. This just shows how much our little community helps each other. I had a problem – put it on the site and you all came through with a solution.
Rick Dennington
#11 posted 12-19-2011 07:27 AM
Great Betsy…...I’m glad they are working out for you….I knew they would if you made a few…..Nice going…..and you even saved a couple of bucks, too…..:)
