Forum topic by dpryor | posted 12-09-2011 08:50 PM | 1466 views | 0 times favorited | 11 replies | ![]() |
Hey everyone… sorry to be so ‘noobish’ when it comes to this but normally I don’t have to ask for help with projects. I recently scored an excellent deal on a PC4210 (out of box) and have run into a peculiar problem. I have followed the manual, even referencing the supplemental manual thinking I was missing something, and for the life of me cannot figure this out. When I cut half blinds, I have the following set up: I am careful in the jig set up – ensuring all marks are lined up and the boards are in the correct placement and orientation – and begin to make the cuts. When I remove what I think are good looking pieces from the jig, I discover that the tails are too large for the pins. I have taken special care to route along all fingers, often times two or three times to ensure all material that should be routed is, only to discover that the tails are larger than the pins they are to go into. What am I missing? Thank you for any help, epiphanies or slaps to the head in regards to helping me with my issue. |
11 replies so far
#1 posted 12-10-2011 05:51 AM |
How thick is your material and you sure you have the depth set properly ? Takes a lot of dialing in and are you using the proper bit. You noted 7 and I believe thats it but it is proprietary with that jig. |
#2 posted 12-10-2011 06:05 AM |
The setup marks on the jig only get you close. In order to dial in the setup for proper depth and offset you need to have some scrap boards that are exactly the same width and thickness as your project. Make a trial cut, make adjustments, cut the end off the test board and try and try again until you get it right. The first few times I used the jig, it seems like it took me at least a half dozen tries to get it right. After more experience and usually hit the sweet spot in 1 or 2 trys. -- Joe |
#3 posted 12-10-2011 08:39 AM |
Are you sure hou have the right bit. I think this jig takes a special bit. |
#4 posted 12-10-2011 08:41 AM |
Guys…do you have to use the PC bushing and dt bit? If so, I’m hosed because the jig was an open box item. I’ve done some searching online and it appears that amazon and eBay don’t carry the PC bushing or bit. Ohh man! Any thoughts? If its not in the bit or bushing, is there anything else you can think of why the tails would be just slightly larger than the sockets? By larger I mean they are wider than the socket width. Depth and height are right on…it looks as though not enough material is being removed from the pins when the router guides along the template fingers. Should I switch to a smaller collar? I’m out of even oddball, off the wall ideas. |
#5 posted 12-10-2011 09:15 AM |
If your using the bit and coller that came with the jig I would suggest buying a new router bit. I like the ones from rockler because they actually mesure the 17/32 that PC recommends and not the 16/32 the bit they give you with the jig. That would be my guess as to what your problem is I always had a heck of a time with set up on mine until some one pointed out that PC sells this jig with the wrong sized bit. also not all 7* bit are the same you need it to be 17/32 wide at the widest point. -- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more |
#6 posted 12-10-2011 12:14 PM |
We need photos -- Joe |
#7 posted 12-10-2011 04:58 PM |
I know this is probably going to be an easy fix, but I just cannot figure it out (mostly out of frustration) at the moment. I am a deck builder and home rehab’er by trade… not much practice with fine woodworking. Thank you for all your help and thoughts guys… I am very appreciative of you helping the “new guy”. Again, I apologize if this is a remedial question… sorry for not uploading photos. I was typing that out last night on my iPhone. |
#8 posted 12-10-2011 06:11 PM |
No apology needed. -- bill@magraphics.us |
#9 posted 12-10-2011 06:17 PM |
Whoah! You mean WAY too big, lol. You’ve got the wrong size dovetail bit. The diameter is too small. I’ve got the same jig but different router. I can measure my actual bit if you like (PM me b/c I’ll forget, lol). -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#10 posted 12-10-2011 09:14 PM |
you are using the wrong size bit and coller again any bit and coller will work as long as they measure out to be 17/32 for the bit at 7* and 3/4” for the bushing. also looks like your bit is to deep but right now that the least of the concerns. -- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more |
#11 posted 12-10-2011 09:34 PM |
after my last post i got to thinking of the depth of your cut you need to raise the bit a 1/32 to 1/16 of an inch. this ma fix this problem. raising the bit will make your tais narrower and pin opening wider. it will also close the gap at the shoulder of the two pieces. try this first. -- I buy tools so i can make more money,so ican buy more tools so I can work more, to make more money, so I can buy more tool, so I can work more |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2102 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4899 |
6689 |
28034 |
CNC Woodworking
211 |
Hand Tools
5403 |
Jigs & Fixtures
1417 |
Wood & Lumber
6223 |
1387 |
Focus on the Workspace
2152 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2197 |
Coffee Lounge
8842 |
