G0555P Bandsaw Blade Problem
Forum topic by John_G posted 12-08-2011 05:48 PM 1372 views 0 times favorited 12 replies Add to Favorites Watch
View John_G's profile
John_G
165 posts in 2688 days
12-08-2011 05:48 PM
Topic tags/keywords: bandsaw blade
Hello everyone, Santa came early for me this year as i got a Grizzly G0555P Bandsaw. It’s a GREAT machine and runs perfectly. However the cut i’m getting from the blade that came with it is less than stellar. It’s not even sandable, it’s something that has to be planed down. Should this be? If not what type of blade should i get, brandname that is.
Thanks everyone, looking forward to your feedback….
-- John Gray
12 replies so far
View 6t5Goat's profile
6t5Goat
71 posts in 3008 days
#1 posted 12-08-2011 05:52 PM
I love Timber Wolf blades..
http://www.suffolkmachinery.com/
View superstretch's profile
superstretch
1531 posts in 2690 days
#2 posted 12-08-2011 05:53 PM
I’d expect the stock blade to be “blah” at best. I have a wood slicer that leaves a sandable finish most times, but I still just run it through the planer once or twice to take down 1/32-1/64 of an inch (if I haven’t fed the wood too quickly). Its faster than sanding and leaves a better finish.
I assume you’re resawing?
-- Dan, Rochester, NY
6t5Goat
#3 posted 12-08-2011 05:53 PM
Double post..
John_G
#4 posted 12-08-2011 06:22 PM
Hey Dan, No just standard cuts, Oak, Mapple, Walnut….. nothing special….
-- John Gray
superstretch
#5 posted 12-08-2011 06:28 PM
What are the specs on the blade you have now? width, tpi..
John_G
#6 posted 12-08-2011 06:31 PM
Not 100% sure, it’s a 3/8 blade that came stock with the machine. Not sure on the TPI, guessing…. maybe 4.
-- John Gray
superstretch
#7 posted 12-08-2011 06:40 PM
Hmm.. You might have a couple teeth that are out of wack. Do you get a fairly straight and square cut?
John_G
#8 posted 12-08-2011 06:41 PM
yeah very nice, i was cutting 1/16”+ stips last night to use for splines…. besides sanding them they came out equal thickness…. i’m guessing it’s a crappy blade….
-- John Gray
superstretch
#9 posted 12-08-2011 06:45 PM
Probably.. I swapped to the wood slicer right away, since I resaw more than anything else on it.. Beautiful cuts
John_G
#10 posted 12-08-2011 06:48 PM
i’ll look into those. Havent done any resawing yet. I have a cpl smaller projects to get done then the mrs’s wants nightstands. So thay may be my first chance to get some thicker stock to resaw down…. we shall see….
-- John Gray
View TheDane's profile
TheDane
5423 posts in 3659 days
#11 posted 12-08-2011 07:37 PM
John—For re-sawing, I like the Highland WoodSlicer ( http://www.highlandwoodworking.com ) ... for everything else, I opt for Carter AccuRight blades ( http://www.carterproducts.com/ ).
The stock blades that are shipped with most saws are junk.
—Gerry
View Bill White's profile
Bill White
4929 posts in 3957 days
#12 posted 12-08-2011 07:48 PM
Listen to TheDane.
Love my Woodslicer.
I use a Timberwolf 1/4” and 3/8” for general work.
Bill
-- bill@magraphics.us
