Experience with Aluminum?
Forum topic by dpwalker posted 534 days ago 658 views 0 times favorited 9 replies Add to Favorites Watch
View dpwalker's profile
dpwalker
186 posts in 1004 days
534 days ago
Does anyone have experience using aluminum in a woodworking project? I am building a small box from Walnut & I want to use diamond plate as a floating panel on the lid. Can someone tell me if the aluminum will move more or less than wood? Thanks in advance.
-- I intend to live forever. So far, so good.
9 replies so far
View HerbC's profile
HerbC
780 posts in 1032 days
#1 posted 534 days ago
Aluminum, being metal, will not change dimension due to changes in moisture/humidity. Wood does change due to changes in moisture in the environment.
On the other hand, metals expand and contract with changes in temperature. In general this should not be a problem in a normal home or office environment.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View gfadvm's profile
gfadvm
6660 posts in 863 days
#2 posted 534 days ago
It won’t move but it will tarnish to an ugly gray and rub off black when handled unless sealed with something. Wax???
dpwalker
#3 posted 534 days ago
HerbC – Thanks for the info. The box will be moving to different locations both indoors & out. Expansion is my main concern in movement. Any idea how much room to leave for expansion? The aluminum piece is 1/16” X 3 3/8” X 18”, I wonder if 1/16” all around will suffice.
gfadvm – I didn’t consider the tarnishing. Thanks for the heads up!
View skeeter's profile
skeeter
233 posts in 1514 days
#4 posted 534 days ago
don’t worry about expansion and contraction. It wont move in normal tempertures. In fact i wouldnt leave any room you don’t want it to rattle. Put some silicone in the groove or something.
-- My philosophy: Somewhere between Norm and Roy
View 000's profile
000
3352 posts in 789 days
#5 posted 534 days ago
Aluminum can be a challenge to get a finish on.
An alkyd poly urethane might be OK because it stays fairly flexible but it’ll still allow O2 to transpire through the film and that’ll allow oxidization of the aluminum.
The first mole layer of Aluminum tends to never actually hold still. which fact is part of why it has historically presented finishing problems.
Anodizing and iriditing aluminum may offer the best potential for a finish.
If it’s shiny you want, I can’t help you having never actually tried to maintain a high polish on aluminum
-- When the moderator chooses sides, his site sucks.
View Lee Barker's profile
Lee Barker
1889 posts in 1023 days
#6 posted 534 days ago
My friend the metals guy says you never see the real aluminum because it starts to oxidize instantly when exposed.
I have lacquered aluminum (after RO sanding, which is interesting) but only for indoor applications.
Are there other plated materials that will give you the look you want, in exchange for some more weight?
Kindly,
View MrsN's profile
MrsN
917 posts in 1698 days
#7 posted 534 days ago
I would put it in with sillicone fairly tight. It shouldn’t move much. I have lacquered, waxed and shellaced aluminum at different times (all in wood jewelry). I sand it a bunch to give it a smooth grey color, metalic but not shiny.Good luck.
-- ----- www.KNWoodworking.com ----- --
View Cgwendling's profile
Cgwendling
8 posts in 613 days
#8 posted 531 days ago
I have several aluminium things that sit outdoors and all I used were aircraft or automotive clear coat. Prep the surface according to the can and spray.
dpwalker
#9 posted 531 days ago
Thanks for the replies & help. I now have the box together am working on completion. I have been reading car enthusiast forums & there are MANY opinions & products to keep aluminum from dulling. I guess I will experiment with a few of these ideas & see how it goes : )
