Glue up went bad-compressed wood
Forum topic by kennyc posted 12-08-2011 01:27 AM 1946 views 0 times favorited 14 replies Add to Favorites Watch
View kennyc's profile
6 posts in 2298 days
12-08-2011 01:27 AM
I recently did a glue up for a cutting board. I did not use cauls, which I usually do. The problem is that I used too much pressure on the clamps and the wood is compressed (basically dented) and the lines are wavy. I tried hot water and to some extent it helped, but it’s still off.
Any suggestions before I throw it into the fireplace?
14 replies so far
404 - Not Found
2544 posts in 2905 days
#1 posted 12-08-2011 10:18 AM
Wet a rag, place it over the dents and press a hot iron down on it. Should pop back out.
Hang on, that’s only for the surface, I think you’re screwed.
View ScottN's profile
261 posts in 2615 days
#2 posted 12-08-2011 04:29 PM
I’ve used the hot iron trick and it works great. Hope it works for you.
-- New Auburn,WI
View MrsN's profile
984 posts in 3461 days
#3 posted 12-08-2011 11:34 PM
do you have any pictures of what happened?
View childress's profile
841 posts in 3477 days
#4 posted 12-09-2011 07:18 AM
Square it up on the table saw. Dents gone… I bet once it’s finished no one will ever notice the “wavy lines” except you ;-)
-- Childress Woodworks
View EandS's profile
73 posts in 2398 days
#5 posted 12-09-2011 07:42 AM
I cant say I have ever seen this problem. I would love to see a photo and look forward to hearing if you find a fix. Just remember dont push it to far…that never ends well…
#6 posted 12-09-2011 02:32 PM
Thanks for the replies.
I tried the iron trick and it helped a bit. I usually do use sticks to apply the pressure evenly, however I rushed the glue up and learned yet another lesson ( after all my mistakes, I should be pretty smart by now. Hahaha)
The lines are not straight because I applied too much pressure. Here is a shot of the wavy line l
As you can see, I trimmed a bit off to show the compression. I will make my final cuts and see what I wind up with. It doesn’t look like I will get it perfect.
View Grandpa's profile
3259 posts in 2611 days
#7 posted 12-10-2011 05:56 AM
I can’t tell from the photo. Do the wavy lines cross the board or so they stop after the 2nd or 3rd course of blocks? If the stop why not cut the glue line and glue on some more blocks? You could salvage some of it and move on. cut it and clean up both sides and re-glue the same piece back on after you straighten the glue line. Would you ever really notice that it is 3/16 smaller in this area????
View gfadvm's profile
14940 posts in 2626 days
#8 posted 12-10-2011 06:04 AM
I kinda like the wavy lines (a nice ‘design feature) and would leave it. But then I like wierd stuff. People will wonder how you did this. Tell em its a trade secret and costs extra.
View Lee Barker's profile
Lee Barker
2170 posts in 2786 days
#9 posted 12-10-2011 08:24 AM
If you clamped enough to distort the wood in that way, I’m wondering if you simultaneously created a glue starved joint. If the board for yourself, you’ve got a laboratory project in progress. If it’s for somebody else, it might be time to start over and consider the extra time just tuition for learning something new about clamping.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
View rance's profile
4255 posts in 3096 days
#10 posted 12-11-2011 12:37 AM
Cut a shallow kerf down that line and inlay a 1/8” x 1/8” stick of contrasting wood. Do em all if you have to make it look uniform.
View RRGR's profile
54 posts in 3270 days
#11 posted 12-11-2011 05:52 AM
When aunt Edna is cutting the Zucchini she wont notice the wavy lines. Can you say merry Christmas?
View MrRon's profile
4676 posts in 3179 days
#12 posted 12-11-2011 06:18 PM
Why does everything have to be symetrical? A few wavy lines adds character and says “I made it”; not from a high tech factory. A small blemish here or there can serve as a personal signature. Everything I make has my personal signature on it somewhere.
View Howie's profile
2656 posts in 2858 days
#13 posted 12-12-2011 01:03 AM
I’m with Lee. Too much pressure can be just as bad as not enough.
Tell people those are there for “character”.
-- Life is good.
#14 posted 12-14-2011 06:05 PM
Thanks for all the input and help!
I finished the board and learned a valuable lesson in not rushing a glue up.
The board is not square and I am definitely concerned about the glue starved joints. I will be keeping this one for myself.
I did the best I could and put some mineral oil on it.
