How to Work Ebony?
Forum topic by CartersWhittling posted 12-07-2011 08:31 PM 3917 views 1 time favorited 12 replies Add to Favorites Watch
View CartersWhittling's profile
CartersWhittling
453 posts in 2876 days
12-07-2011 08:31 PM
Topic tags/keywords: question gaboon ebony
Hello. I just bought a small amount of gaboon ebony for a picture frame. The frame is japanese inspired with half lap joints in the corners, similar to this picture.
The ebony was partially air dried and is coated with wax. The store I bought it from has atmoshpere conditions the same as where I live. I am wondering how to go about working it. How long should I let it sit before milling, should I roughly mill then let it sit for some time, etc…? The blanks themselves are about an inch thick and 2” – 3” wide. Also, what glue should I use to join the half laps?
Any help and advice would be greatly appreciated.
-Curt
-- And whatsoever ye do, do it heartily, as to the Lord... Colossians 3:23
12 replies so far
View Bertha's profile
Bertha
13551 posts in 2895 days
#1 posted 12-07-2011 08:36 PM
I’ve worked a fair bit with ebony, mostly on the lathe. If you’ve never used it before, you’re in for a real treat. On the lathe, it’s a blast. It also handplanes beautifully. I’m sure that given the oil content, there’s a particularly appropriate glue, but I’m unaware of it. I heated the surfaces a tad to drive out the oil, wiped it down, then used good ole Tightbond III. Good luck1
View Charles Maxwell's profile
Charles Maxwell
1099 posts in 4009 days
#2 posted 12-07-2011 09:16 PM
I use ebony in my clocks and Bertha’s comments above are spot on. I use titebond and never had a problem. Don’t need to wait before milling. And, do put some on the lathe just to see how well it turns. A thing of beauty. Absolutely love working with ebony.
-- Max the "night janitor" at www.hardwoodclocks.com
View chrisstef's profile
chrisstef
17761 posts in 3208 days
#3 posted 12-07-2011 10:26 PM
Ive used acetone on oily woods to clean the surface before gluing, it was cypress to be specific. Ive never worked with ebony though.
View DS's profile
DS
3033 posts in 2622 days
#4 posted 12-07-2011 10:53 PM
Ditto on acetone before gluing. It allows a better adhesion.
In violins, the only acceptable glue for purists is hide glue. (Allows disassembly for repairs)
Scrapers and planes do well with ebony. Not sure what the hardness score is, but it is way up there.
Titebond works well for more permanent adhesion.
CartersWhittling
#5 posted 12-07-2011 11:00 PM
Thanks for the advice. I also just emailed the shop I bought the wood from asking them the same question.
View Bill White's profile
Bill White
5128 posts in 4162 days
#6 posted 12-07-2011 11:17 PM
WHAT???? Ya don’t believe us? Jokin’!!!!
Acetone and a pva glue will do ya just fine.
I like the design, and will we get a chance to see the finished product.
I forgot. Can I have the off cuts?
Bill
-- bill@magraphics.us
CartersWhittling
#7 posted 12-07-2011 11:25 PM
haha no. I am keeping my expensive off cuts. I will post the picture and frame when it is done. The picture that the frame is for, is a sketch of a tiger that I drew. It is going to be a gift for my mother.
View Bill Davis's profile
Bill Davis
226 posts in 4126 days
#8 posted 12-08-2011 02:25 AM
I have worked with Makassar Ebony or Kamagong from the Philippines and I agree it works real nice and glued up without problem. You can see pictures in my projects. http://lumberjocks.com/wmodavis/projects and http://lumberjocks.com/wmodavis/blog/20640
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3238 days
#9 posted 12-11-2011 01:16 AM
You might notice that I use it a lot in my projects, glued with PVA. No problems. If you’re really worried about it wipe with white spirit (mineralised spirit) and allow that to evaporate off before gluing.
CartersWhittling
#10 posted 12-11-2011 05:29 AM
Alright thanks. After contacting the shop I bought the wood from they said the lumber should be stable. They just recommended to rough mill it and let it sit for some time just to be safe. I have Titebond III so I will use that.
View tnwood's profile
tnwood
261 posts in 3288 days
#11 posted 12-11-2011 05:12 PM
Ebony tends to chip out easily so make sure any cutting tool you use is very sharp. It finishes quite easily and sometimes just a coat of wax on a cleanly planed surface is sufficient. It is so dense it doesn’t absorb oil finishes well. I have also used patina blond shellac which gives more protection.
Bill Davis
#12 posted 12-11-2011 06:20 PM
I have used both lacquer (sprayed) and mineral oil as a finish on Ebony and liked both but they are quite different. As tn said an oil finish is not absorbed well. It is definately not a ‘do and forget’ finish and has to be renewed periodically. But I liked it in the project I used it on. The jewelry box I left unfinished.
